Posted: Sat Sep 29, 2007 2:54 pm Post subject:
Audio-driven s&h goes positive |
This might just be because I'm a bit tired, but I got this weird behavior whilst messing about with a noise-drive bincounter. Look at this patch. The noise module goes through a s&h, via a couple of inactive modules in to the trig input of a OscPerc, that is piped to output, but there is no sound. If you activate the high-pass filter you get sound, as if you convert the signal from positive to bipolar, which leads me to believe that the noise signal is offset upwards. But it shouldn't be, should it? Is the G2 confused by the orange cable going from the BinCounter module?
OMG As I was writing this, and looking at the help file for the S&H, the sound came on, without me really doing anything in the editor! Now I don't know what to believe - am I being delusional?
Ehm... I'll submit the post anyway. Maybe someone can see something? Has anyone had a similar ghostly experience?
/Stefan
Description: |
Download |
Filename: |
strange_snh.pch2 |
Filesize: |
1.22 KB |
Downloaded: |
2424 Time(s) |
_________________ Antimon's Window
Joined: Apr 03, 2004 Posts: 24083 Location: The Netherlands, Enschede
Audio files: 278
Posted: Sat Sep 29, 2007 4:06 pm Post subject:
Re: Audio-driven s&h goes positive |
Antimon wrote: | which leads me to believe that the noise signal is offset upwards. |
Tiredness, I'm sure ... but wait ... what about the ghostly experience ...
You clock on the noise itself, a clock will occur when the signal goes from 0 to >0, so indeed you always sample the noise when it's positive - it does fluctuate though in it's positiveness so the filter works to make it audible.
Is it OK now when I move this out of the bugs section?
... but wait .. what about the ghostly experience ... that one would be the bug maybe ... hearing noise would mean repeated triggers for the perc osc. I cAN'T EXPLAIN THAT ...oops sorry for the caps, but the ghost just came in here as well
I can only explain this with an untested hypothesis _________________ Jan
Audio files: 278
Posted: Sat Sep 29, 2007 4:40 pm Post subject:
untested .. but repeatable ... after a while apparently very quickly after the positive edge immediately a negative one follows and due to timing delays that one can be sampled ... I didn't have the patience yet to see if the ghost would stop again ...
Nice find _________________ Jan
Audio files: 278
Audio files: 278
Posted: Sun Sep 30, 2007 3:05 pm Post subject:
Thanks for checking this out. Great to know that ...something is repeatable. I like your second patch - will check it out later to see what happens when (if) the issue kicks in.
I understand now how the signal ends up in the positive, and what I thought was a bug was indeed the correct behavior. It's not that often that you start writing a bug report before the actual bug has even happened!
Joined: Jan 31, 2003 Posts: 18198 Location: Durham, NC
Audio files: 213
Posted: Sun Sep 30, 2007 3:33 pm Post subject:
Jan, that last patch is amzing.
I can get great things by adjusting the controls on modules I have no idea as to their function and it keeps playing beautiful tones.
What a great cracklebox. _________________ --Howard
my music and other stuff |
Audio files: 278
Posted: Sun Sep 30, 2007 3:51 pm Post subject:
Antimon wrote: | Thanks for checking this out. |
No problem, I had fun doing it
Glad you guys liked that last patch, making it was a good part of the fun _________________ Jan
Audio files: 278
Posted: Sun Sep 30, 2007 3:58 pm Post subject:
Oh Howard, if you feel like it, please post some variations ! _________________ Jan
Audio files: 213
Posted: Mon Oct 01, 2007 10:59 am Post subject:
Well, Jan, I'm not going to do that. I'll tell you why.
This circuit reminds me of Rob's Bleepobox, or whatever he calls it. His thingie has about 20 knobs that who knows besides Rob what they do, and he says he sometimes can't remember. The nice thing is that the Bleepobox keeps on playing with almost any combination of settings. It just changes it's tune slightly.
Your patch is something like that. So, a variation is like a snapshot of a sunset, in this case. I have found that, except for rare occasions - like the sunset on the beach in The Hague at the modular meeting in 2004 - it's better just to relax and enjoy it as sunset progresses, rather than trying to capture it with a camera which involves exposure, framing, etc.
That said, here is a version of your patch. I changed some stuff. I don't remember exactly, and did some knob assigments. It just uses pages A1 and A2. More knobs could be assigned but this is a good thing nonetheless. There are 8 variations but the idea is to turn the knobs, not use the variations.
Description: |
Some changes to Blue Hell's patch and bringing controls to the A1 and A1 pages. This is sort of a playable noodle, or a playable interlude music maker. |
Download |
Filename: |
strange_snh_hm_6.pch2 |
Filesize: |
2.65 KB |
Downloaded: |
3041 Time(s) |
Audio files: 278
Posted: Mon Oct 01, 2007 11:20 am Post subject:
will check it out. _________________ Jan
