AS3394 6-voice Synthesizer for DIY
Page 1 of 1 [15 Posts]
PropB3
PostPosted: Mon Mar 22, 2021 9:36 am    Post subject: AS3394 6-voice Synthesizer for DIY Reply with quote  Mark this post and the followings unread
Hello,
I want to share my latest Projekt. 6-voice Polyphonic synth using the AS3394 and an PIC as Controller Chip. You may have a look at:
https://hbo-synthesizer-workbench.jimdofree.com/
to get more Infos.
Let have fun.
 Filesize:  177.41 KB
 Viewed:  315 Time(s)
AS3394_Firmware.zip
 Filename:  AS3394_Firmware.zip
 Filesize:  167.47 KB
 Downloaded:  398 Time(s)
AS3394_Synth.pdf
 Filename:  AS3394_Synth.pdf
 Filesize:  948.1 KB
 Downloaded:  605 Time(s)
PostPosted: Mon Mar 22, 2021 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Congrats on this great project!
my synth
LFLab
PostPosted: Wed Mar 24, 2021 3:13 am    Post subject: Reply with quote  Mark this post and the followings unread
That is a VERY tidy layout of that board, nice!
Sounds great also, are you going to integrate this into a case or is the journey the goal? Smile
PostPosted: Tue Jun 29, 2021 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Impressive layout. Love this DIY project ! Well done.
Bill
THeff
Audio files: 33
PostPosted: Wed Feb 16, 2022 10:32 am    Post subject:
Subject description: Built AS3394, works great!
Hi Hubert,
As you see I built your AS3394 6 Voice synth and it works great! Thanks for posting this great project. If you are seeing this post I have been trying to contact you via the email on your HBO Synth website with no response. I'm interested in obtaining the firmware for the Vitellius 1 Teensy synth.
Regards,
THeff, Florida, USA
 Filesize:  7.88 MB
 Viewed:  192 Time(s)
 Filesize:  8.27 MB
 Viewed:  184 Time(s)
 Filesize:  8.41 MB
 Viewed:  201 Time(s)
blakeAlbion
PostPosted: Tue Oct 11, 2022 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Regarding this post, how would I create a set of PCBs using the links provided here? I have never fanned a pcb before.
Thanks,
Ben
craigbarnes
PostPosted: Sun Oct 29, 2023 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the developer still around, I too am in search of the source code for the Vitelliuis 1 synthesizer to port to a Teensy 4.1 from 3.2, I have used the contact form a couple of times but I think Hubert is not around any more.
Audio files: 213
PostPosted: Sun Oct 29, 2023 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
craigbarnes:
Try sending him a PM, or use the contact form on his website.
craigbarnes
PostPosted: Mon Oct 30, 2023 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
craigbarnes:
I sent an email to poly61@rocketmail and that bounced immediately, I used the contact form twice, I'm guessing that goes to the same place, but no bounce or notification.
I will try a PM.
Thanks
Audio files: 213
PostPosted: Mon Oct 30, 2023 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well if you have an extra $30,000 or so just pick up one of these Shocked
 Filesize:  1.06 MB
 Viewed:  30 Time(s)
craigbarnes
PostPosted: Tue Oct 31, 2023 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
So I got a reply from PropB3 and unfortunately he is not willing to share his code. Even though a Teensy 3.2 is no longer available the guy is too selfish or arrogant to share so others in the DIY community can carry on his good work.
I have over 40 projects on my github page and I share everything, I don't understand some people.
Audio files: 213
PostPosted: Tue Oct 31, 2023 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, sorry you couldn't get the code you want, but please refrain from calling people names on this forum. This not Facebook or X. Thanks...
craigbarnes
PostPosted: Tue Oct 31, 2023 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will speak how I feel and his attitude stinks.
I'm.sat here and can be hot by a Russian missile or drone at any moment but I still find the time in-between the constant air raids to publish my work and help people who message me, perhaps I should stick to Facebook
Audio files: 213
PostPosted: Wed Nov 01, 2023 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
You are welcome here...
blakeAlbion
PostPosted: Thu Jan 25, 2024 7:36 am    Post subject: PCBs? Reply with quote  Mark this post and the followings unread
Please help.
How can I obtain PCBs for this project?
Is the only option to laser print the PDFs and then do an etch?
I do not live in a location where I can do etching.
Aside for trying to reverse engineer the layers into gerbers, is there any way to use these images to have boards fabricated for me?
Thanks,
Ben
