 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
Elastic Audio V1.0
Page 1 of 1 [9 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Sun Mar 05, 2006 1:31 pm    Post subject:  Elastic Audio V1.0
Subject description: realtime sample time/pitch manipulation
Here's my spin on the granular thing. This patch lets you capture 2.7 seconds of audio material. After capturing, you can:
-Continuously manipulate the speed of the playback -from full forwards to freeze to full backwards -without affecting pitch.
-Conversely, change the pitch of the sample up or downward -without affecting speed.
-Freely scrub around in the sample -again, without affecting pitch.
The playback speed is set to zero default. So, after capturing, you won't hear anything right away. I have assigned the (bipolar) pitch stick to the (bipolar) playback speed and the modwheel to the scrubbing position. This way, you can dynamically shuttle back and forth in the sample with the pitch stick and scrub around at leisure with the wheel. Fun.
All controls are also represented on the panel (Page A1). There's also a tuning knob there to tune the sample (regardless of speed).
The last three parameters (grains rate, pitch jitter, readout position jitter) pertain to the granular synth engine of the patch. "Grains rate" controls the speed (and size) of the grains. The jitter parameters, used conservatively, are helpful to "mask" the artefacts caused by the (constant) granulising frequency (especially at high rates). (Without those, the patch sounds identical to old timestretch algorithms on vintage samplers, which is also nice). Cranking up the jitter parameters just warbles the stuff around -fun too.
A cool patch for live jamming. Fits on one DSP. (I squeezed it into the FX section). Enjoy.
best,
tim
ElasticAudio TK.pch2
 Filename:  ElasticAudio TK.pch2
 Filesize:  4.31 KB
 Downloaded:  2716 Time(s)
Former site admin
Audio files: 353
PostPosted: Sun Mar 05, 2006 2:35 pm    Post subject: Re: Elastic Audio V1.0
tim wrote:
A cool patch
I'll 2nd that, thanks !
ian-s
Audio files: 43
G2 patch files: 626
PostPosted: Sun Mar 05, 2006 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
3rded, daed si luaP!
Spandex
PostPosted: Sun Mar 05, 2006 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice one.
Lovely Cloakroom.... Lovely Cloaks
PostPosted: Sun Mar 05, 2006 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had to put that through tim's patch inorder to confirm deknow's sneaking PBS suspicion that it's true.
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sun Mar 05, 2006 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Absolutely awesome patch in both usefulness and sheer G2 wizardry.
mother misty
G2 patch files: 130
PostPosted: Tue Mar 07, 2006 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Brilliant patch tim! thumb up
I'm having so much fun with this one.
Thanks for sharing.
Former site admin
Audio files: 353
PostPosted: Tue Mar 07, 2006 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also see : http://electro-music.com/forum/post-70034.html for other versions of this patch. And here : http://electro-music.com/forum/post-70080.html
Unfed
G2 patch files: 11
PostPosted: Thu Nov 30, 2006 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
here's a fun example of what this can do. i think all i did was capture a part of the loop (not a very good job at that) and started twisting knobs. i could do this for hours...
(took me a while to find which patch i'd used, i didn't save it to the synth at the time.)
amen, mother.mp3
a familiar drum loop sampled and manipulated by the G2...
 Filesize:  8.25 MB
 Viewed:  2096 Time(s)
