bugbrand
Posted: Wed May 03, 2006 6:48 am Post subject:
S/H => bitcrusher-style |
A sample&hold should work fine as a sample-rate-destroyer, right?
(I was thinking bit-crusher, but that's bit depth whereas this is sample rate)
I was thinking to make use of the AD781s I got from Analog.com -- they're 8pin dip Sample & Hold amplifiers... Should be as simple as making a variable speed pulse-osc ranging from 44.1k down to ... low..?..(plus, of course, preamping etc)
Or am I being wrong?
***EDIT***
Read through this thread for details on the AD781 based Audio Sample Rate Reducer design - the BugCrusher
There are two schematics hosted on electro-music on this thread:::
http://electro-music.com/forum/topic-13444.html _________________ http://www.bugbrand.co.uk
http://www.bugbrand.blogspot.com Last edited by bugbrand on Thu Sep 21, 2006 1:22 am; edited 1 time in total |
Joined: Jan 31, 2003 Posts: 17924 Location: Allentown, PA
Audio files: 151
Posted: Wed May 03, 2006 8:56 am Post subject:
Description: |
Filesize: |
22.79 KB |
Viewed: |
38602 Time(s) |
Description: |
 Download |
Filename: |
s-h.mp3 |
Filesize: |
330.68 KB |
Downloaded: |
2345 Time(s) |
_________________ --Howard
my music and other stuff |
bugbrand
Posted: Thu May 04, 2006 2:33 am Post subject:
Hey Howard that sounds ACE! Yes, super simple..
BUT! I tried out with the AD781 yesterday and I got masses of signal bleed from the sample-trigger signal..
The 781 requires very few extra parts so breadboarding was easy - fed a function gen in but you require very short pulse signals, so I added a pulse converter with two 40106 gates.. Lots of bleed through. argh, so I tried making another of the 40106 gates into the osc (thought this may help..) - still loads of bleed through (..the sample-trigger signal needs to be 0-5v whereas the rest runs at +/- 12v)
The sounds, apart from the bleed through, were really gnarly and good.. May make a good lofi effect.
I'll try some more ideas out today..
DARN - and I REALLY need to get my MicroModular back again (..its currently been sitting in london for a few months..) _________________ http://www.bugbrand.co.uk
Audio files: 151
Posted: Thu May 04, 2006 5:36 am Post subject:
Yes, the 781 seems to be a little bit different than the NM S/H module in that it is not edge triggered.
Maybe if you clock it with a square wave oscilator with a adjustable pulse width you'd get good results. _________________ --Howard
bugbrand
Posted: Thu May 04, 2006 6:21 am Post subject:
YES - more findings = things sound good!
You're right Howard - the problem was with the non-edge triggering. I'd kind of figured that yesterday - 'cos it was working like a sqr-wave trem at low rates.
Well, I adjusted some things and found that its very simple to make something pretty darn ace - and the bleedthrough is almost gone by making the Sample trigger pulse really narrow (it could probably go even narrower..)
So, I did a quick schematic (which shows just how simple it is..):
Proto RateReducer Schematic
And uploaded a couple of quick demo sounds of a 505 and a guitar going through it (..this was using a modular preamp to boost the signals first and then going out through modular mixer - so treating this circuit as a new processing module.)
505 and guitar
guitar hits - good drum sounds? _________________ http://www.bugbrand.co.uk
bugbrand
Audio files: 151
Posted: Thu May 04, 2006 7:30 am Post subject:
Sounds good. A certain amount of bleed through is to be expected with this kind of circuit.
Nice cheap narrow pulse oscillator you have built, BTW... _________________ --Howard
bugbrand
Posted: Fri May 05, 2006 1:28 am Post subject:
mosc wrote: | Nice cheap narrow pulse oscillator you have built, BTW... |
..yet another tip from the ever-useful Music From Outer Space - Micky Mouse Logic
I really feel the need to make this voltage controllable (have the rate controlled) - - so how to simply turn a 40106 into a VC(LF)O? ...
Well, looking on René Schmitz's site, there's the drive part of the 3phase LFO - the drive part is here made from 1/4 of a 4093 with the two inputs tied together - so I figure a gate of the 40106 can replace this.. Hope to try out asap 'cos I want this module built already.!. _________________ http://www.bugbrand.co.uk
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Posted: Fri May 05, 2006 4:51 am Post subject:
very nice samples from both.
i placed a sample order from analog.com, so this is soon under my soldering iron _________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
piedwagtail
Posted: Fri May 05, 2006 9:09 am Post subject:
Good work Tom,
Any reason i can't do this with the LF398?,i have a stash of early cans.....
being not so needy of the ultra-scramble
putting a LDR around the 1M pot might be feasible for mild changes.(empirically parallel or series)
and a LDR/vactrol vc-mixer to vary the clean to scramble mix.
Is Farnell,via Newark,the only way to get vactrols over here?
The £12.95 postage is pain for $1 devices....
Robert |
dnny
piedwagtail
Posted: Sat May 06, 2006 7:23 am Post subject:
I love those samples!
Well done. _________________ What makes a space ours, is what we put there, and what we do there. |
toppobrillo
Joined: Dec 10, 2005 Posts: 766 Location: oakland, ca
Posted: Sat May 06, 2006 9:17 am Post subject:
sounds good! |
bugbrand
Posted: Sun May 07, 2006 4:00 am Post subject:
Cheers.
I fully intended to try out the VC rate control idea yesterday,
But then I got a Modular G2 Rack.. so I didn't have any time left over (not surprising really - the G2 is freaking amazing. Really, I don't know any system that comes close to its wonders)
But I will try to investigate tonight -> G2 or not, still got to make more synth modules.. _________________ http://www.bugbrand.co.uk
dnny
Posted: Sun May 07, 2006 11:40 am Post subject:
bugbrand wrote: | G2 or not, still got to make more synth modules.. |
happy to hear that your not leaving the DIY for one rack:)
and congrats for the new awesome G2 _________________ Association of experimental electronics
www.koelse.org
Audio files: 151
Posted: Sun May 07, 2006 12:22 pm Post subject:
Congrats on the G2...
IMHO, the G2 makes a superb platform for debugging ideas for DIY circuits. _________________ --Howard
toppobrillo
Posted: Sun May 07, 2006 7:24 pm Post subject:
yes, definitely, i have been using the demo and though my PC will only allow me to run about 8 modules or so, [yeah its pretty slow] i have been able to experiment instantly with ideas that i wouldn't otherwise or would have taken hours to breadboard and test.[not to mention tearing down whats already breadboarded.] so yep tell your friends about it. free sound circuit prototyping software. |
bugbrand
Posted: Mon May 08, 2006 1:39 am Post subject:
piedwagtail wrote: | Good work Tom,
being not so needy of the ultra-scramble :)
Robert |
Thanks Robert -
I don't really know the LF398 - maybe its an edge triggered device and therefore EVEN EASIER to use than the AD781? _________________ http://www.bugbrand.co.uk
piedwagtail
Posted: Mon May 08, 2006 7:11 am Post subject:
Tom,
LF398:I'll have to do my homework,i've used them in Grenader S/Hs without difficulty.
I'm knee deep in oscillators at the moment,so i'll wait to hear your forthcoming voltage controlled samples
If you're up to London,i can add another rack:a 4.5U sub frame,used to be a Wayne Kerr ballistics analogue computer.Fits a 19" and has 5 plug in cards.(Don't think i'll fit it in my lifetime achievement schedule )
Robert |
Posted: Tue May 09, 2006 1:34 am Post subject:
"Wayne Kerr"!!??
That's got to be a joke right?  _________________ What makes a space ours, is what we put there, and what we do there. |
piedwagtail
Posted: Tue May 09, 2006 7:26 am Post subject:
Looks like a fine company.
It's just an unfortunate name. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Tue May 09, 2006 7:29 am Post subject:
Uncle, I know what you mean.
Quote: | Wayne is the best, besides Jesus. |
http://www.independentbands.com/cd/waynekerr/brandnewday.html
Quote: | Wayne Kerr's music meets two very important criterias, his music is both annoited and cutting edge. |
okdokey _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Tue May 09, 2006 7:31 am Post subject:
However, that hardware looks like some serious shit!
Flickr |
