Properties on removable USB Memory Devices
Post new topic   Reply to topic Moderators: blue hell
Page 1 of 1 [4 Posts]
Former site admin
Audio files: 353
PostPosted: Fri Apr 07, 2006 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Next I need to figure out how to stop it displaying several splash screens before I'm able to remove the usb stick 'safely' (on the Mac you either press 'eject' or you simply drag the icon to the trash- nice and simple.)
Ok, this is hidden a bit ... put the USB stick into the computer and start a file explorer (my computer or whichever of the incarnation you like most) and click right on any diskdrive. Select properties from the popup menu and then go to the hardware tab. Select the USB drive from the list and click on the properties button. In the window then popping up go to the policies tab and select "optimize for quick removal" (turning of write caching). Click OK a few times, and from now on you can simply pull out the USB stick when it's light is off, no need for safe removal or eject.
AFAIK this is a per computer setting, so you'll want do this on every XP box you use the stick with.
Audio files: 21
PostPosted: Fri Apr 07, 2006 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
On a mac you simply unmount the volume. A spontanous pull-and-go is not recommended.
Flickr
Audio files: 266
PostPosted: Fri Apr 07, 2006 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Yikes, I just moved this from the Mac forum. Laughing
Audio files: 21
PostPosted: Fri Apr 07, 2006 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm.. no boots?
Flickr
