 Forum index » electro-music.org
A minor milestone.
Page 1 of 2 [45 Posts]
Cyxeris
PostPosted: Thu Feb 12, 2004 2:17 pm    Post subject: A minor milestone. Reply with quote  Mark this post and the followings unread
Our users have posted a total of 8088 articles
We have 270 registered users
The newest registered user is Djzleite
In total there are 4 users online :: 3 Registered, 0 Hidden and 1 Guest
Most users ever online was 27 on Fri Nov 28, 2003 11:01 am
Registered Users: Cyxeris, elektro80, themoors
_________________________________________________________
Intel 8088
From Wikipedia, the free encyclopedia.
Introduced June 1, 1979
Clock speeds:
5MHz with 0.33 MIPS
8MHz with 0.75 MIPS
Internal architecture 16 bits
External bus Width 8 bits data, 20 bits address
Number of Transistors 29,000 at 3 μm
Addressable memory 1 megabyte
Identical to 8086 except for its 8 bit external bus
Used in IBM PCs and PC clones
The Intel 8088 was a computer processing unit (CPU) based on the 8086, with 16-bit registers and an 8-bit external data bus. The processor was used in the original IBM PC.
The 8088 was targetted at economical systems by allowing the use of 8-bit designs. Large bus width circuit boards were still fairly expensive when it was released. The prefetch queue of the 8088 is 4 bytes, as opposed to the 8086's 6 bytes. The descendants of the 8088 line include the 80188, 80288 (obsolete), and 80388 microcontrollers which are still in use today.
The most influential microcomputer to use the 8088 was, by far, the IBM PC. The original PC processor ran at a clock frequency of 4.77 MHz.
Apparently IBM's own engineers wanted to use the Motorola 68000, and it was used later in the forgotten IBM Instruments 9000 Laboratory Computer, but IBM already had rights to manufacture the 8086 family, in exchange for giving Intel the rights to its bubble memory designs. A factor for using the 8-bit Intel 8088 version was that it could use existing Intel 8085-type components, and allowed the computer to be based on a modified 8085 design. 68000 components were not widely available at the time, though it could use Motorola 6800 components to an extent. Intel bubble memory was on the market for a while, but Intel left the market due to fierce competition from Japanese corporations who could undercut by cost, and left the memory market to focus on processors.
A compatible replacement chip, the V20, was produced by NEC for an approximate 20 percent improvement in computing power
∆ Cyx ∆
"Yeah right, who's the only one here who knows secret illegal ninja moves from the government?"
-Napoleon Dynamite
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger
Audio files: 21
PostPosted: Thu Feb 12, 2004 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cute!
Trivia: The Motorola 68000 is the one Apple went for. Way back, in those days proper engineers would of course choose the 68000 series.
A lot of unix gear ended up with 680xx series CPUs.. and if I remember correctly.. even the early 90s Atari Falcon went for the 680xx series.
Apple stopped using the 68000 series in the mid 90s. At that time it had developed into the 68040. Motorola kept upgrading it and I seem to remember they had a 060 prototype out.
Flickr
Cyxeris
PostPosted: Thu Feb 12, 2004 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
When we achieve 68,000 posts (or members), you will be in the spotlight! Wink
Of course, at that point, so will Howard. Can you imagine 68,000 users? 68,000 with the same 20 people posting all the messages beyond the first 1 or 2 from the rest. People need to get involved more.
Cyx
∆ Cyx ∆
-Napoleon Dynamite
Audio files: 21
The 8088 is still with us. These days it is used, in modern incarnations, for embedded processing tasks.
Typical product:
NMIS-0025 V25 (8088 compatible) based CPU board
2x4"s[tm] single board computer with 2 channel TTL serial communication, 1 Meg address, 2 memory sockets, 32K SRAM[
The NMIS-0025 is New Micros' NEC-V25-based CPU board for the 2x4"s[tm] board series. A valuable feature of the NMIS-0025 is its code compatibility with the IBM PC's processor, offered on a miniature board format.
FEATURES:
V25 CPU with 16-bit internal architecture
Software compatible with 8086/8088
Programmable Interrupt Controller
Two DMA controller channels
3 parallel ports
2 Asynchronous Serial Channels
8-channel Voltage Comparator
Time Base Counter
16-bit Timer
Programmable Wait State Generator
1/4K RAM
1M address space
Two 32-pin JEDEC memory sockets
Flexible address decoding, socket assignments
Battery backup circuits for memory
44-pin JEDSTACK[tm] Vertical Stacking Connector (VSC-44)
Low power (45mA w/2-32K RAMs at 8 MHz)
The NMIS-0025 is a complete system, ready to run dedicated applications. Only the addition of the user program is required, in its battery backed RAM, or in a user-supplied ROM/EPROM/EEPROM.
The 2x4"s[tm] series of computer boards were designed with low power operation and minimal size in mind. The 2x4"s[tm] are the perfect building blocks when designing systems or stand alone single board computers. They were named 2x4"s[tm] for their size, 2 x 4 inches, and to emphasize their similarity in concept to the popular mechanical building block.
The sockets accepting JEDEC memory devices have flexible pinouts. Refer to the figure at the left.
To download code to the NMIS-0025's processor, or interactively develop code, additional circuitry is needed to "talk" to the systems with RS-232. A level shifter must be used with terminals, or personal computers, with RS-232 ports to convert the TTL serial in and serial out to RS-232 levels. This can easily be accomplished with an NMII-0232 board. Refer to the figure above.
The NMIS-0025 makes a very cost effective solution as a target system, particularly when small size, CMOS low power and ease of development are required. No other single board computer has these unique features in such a small space, and 8086 code compatibility. High Level Language support offers resident FORTH and, optionally, BASIC and Assembly Language. FORTH and C cross compilers and cross assemblers are also available.
Flickr
Cyxeris
PostPosted: Thu Feb 12, 2004 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
We waste an aweful amount of processing power in general.
I always wanted to get a nice clean 4004 and make a necklace charm out of it.
Cyx
∆ Cyx ∆
-Napoleon Dynamite
Cyxeris
PostPosted: Thu Feb 12, 2004 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
The Motorola 68000 is the one Apple went for. Way back, in those days proper engineers would of course choose the 68000 series.A lot of unix gear ended up with 680xx series CPUs.. and if I remember correctly.. even the early 90s Atari Falcon went for the 680xx series.
You mustn't overlook the esteemed Amigas, my friend.
Cyx
∆ Cyx ∆
-Napoleon Dynamite
Audio files: 21
PostPosted: Thu Feb 12, 2004 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right... true.. but I ended up with Apple boxes very early. But I did in fact have a C64 which I used for dbase.
Flickr
Cyxeris
PostPosted: Thu Feb 12, 2004 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used to have a mint condition C128. No idea what came of it.
I started out on a PC back in 1985 that my father had built for me. I was 7.
Cyx
∆ Cyx ∆
-Napoleon Dynamite
Audio files: 21
PostPosted: Thu Feb 12, 2004 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm.. I am sorry I forgot mentioning 7400 when we hit 7400 posts.
I messed around with TTLs a lot when I was in my early teens. great fun.
I looked up the 7400 series at Gateway Electronics right now. Nice prices.
Hmm.. Gateway has some cute kits:
http://www.gatewayelex.com/kits1.htm
But these are not anything like the wonderful stuff made by Heathkit way back. http://www.heathkit-museum.com/
Posted Image
Posted Image
Hmm.. I might want that KIT-227 from gateway... hmm.. where is the schematics?
Flickr
Audio files: 267
PostPosted: Thu Feb 12, 2004 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Posted Image
http://ccrane.com/fm-transmitter.asp
Maybe a better choice for the small FM transmitter. I have one. Works very well.
Audio files: 21
PostPosted: Thu Feb 12, 2004 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
HEY! CUTE!
Flickr
Audio files: 267
PostPosted: Thu Feb 12, 2004 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
When I was a kid, 13 years old, I got one of these, a Heathkit Mohawk. It took months to build. When it was finally finished, it didn't work. A nice ham who owned a TV repair shop (remember those?) fixed it for me. He said there was one cold solder joint. That was the most wonderful radio in the world. I made my first electronic music on that machine. It had a tuneable BFO.
If there is a heaven, forget the 74 virgins, I'd just want to tune one of those. Razz
http://www.heathkit-museum.com/ham/rx-1.shtml
It was huge. 50 pounds. 20 Kilos (I think)
Cabinet size: 19½" W x 11 5/8" H x 16" D.
Cyxeris
PostPosted: Thu Feb 12, 2004 4:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is it, exactly, that we find so cool and so intriguing about the most uncool gear? The more uncool it is, the cooler it is to us. What is that? Our own flavor of counterculturism, I suppose, and I love it.
Cyx
∆ Cyx ∆
-Napoleon Dynamite
Audio files: 267
PostPosted: Thu Feb 12, 2004 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you saying the Mohawk is uncool? Shocked
Here's a better picture...
Posted Image
Cyxeris
PostPosted: Thu Feb 12, 2004 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gotta love those. One of my Junos has developed cold joints on the main out jacks' contacts. This is the third time in some 4 years. I think it's time to get rid of the crud that is on them right now and try silver solder on those bad boys.
Cyx
∆ Cyx ∆
-Napoleon Dynamite
Audio files: 21
PostPosted: Thu Feb 12, 2004 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
No no no! The Mohawk is way cool! And I even an old bakelite Siemens field meter from 1936 or so.. way kool!
Stuff like the Mohawk are cutural icons.. human artifacts.. this is not just gear! It is aboout who we are and why we are and the way we imagien our world.
Flickr
Audio files: 21
PostPosted: Thu Feb 12, 2004 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Flickr
Cyxeris
PostPosted: Thu Feb 12, 2004 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Absolutely. Allow me to elabourate...
Cool
Posted Image
Uncool
Posted Image
Cool
Posted Image
Uncool
Posted Image
Cool
Posted Image
Uncool
Posted Image
I can provide additional examples upon request. Wink
Cyx
∆ Cyx ∆
-Napoleon Dynamite
Audio files: 21
PostPosted: Thu Feb 12, 2004 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes please!
Flickr
Audio files: 267
PostPosted: Thu Feb 12, 2004 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Coolness is in the mind of the beholder, I suppose. Crying or Very sad
Audio files: 21
PostPosted: Thu Feb 12, 2004 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW, do you still have that Mohawk?
Flickr
Cyxeris
PostPosted: Thu Feb 12, 2004 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Exactly. We defign our own "cool," which has an overwhelming tendancy to be that which the majority would consider the pinnacle of "uncool." No pity for the majority.
Cyx
∆ Cyx ∆
-Napoleon Dynamite
Audio files: 267
PostPosted: Thu Feb 12, 2004 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
No. Crying or Very sad
After high school, I went away to college and loaned the Mohawk to a friend. He in turn loaned it to an old ham who needed a receiver. When I returned home on a trip about a year later, I asked for the Mohawk back. My friend called the old man. It turns out that he died and the wife thought the Mohawk belonged to him - and sold it. My friend was very upset. He insisted in paying me for it. He still feels terrible about it, although I don't have any hard feelings. Since then, I've many times come across used Mohawks for sale, but they wouldn't do it for me. Not the same as the one I built when I was a kid. I always look inside to see if my "mark" is inside. I could instantly recognize the one I built. I do have a very excellent vintage ham tube receiver; a Drake 2A.
Posted Image
I used this baby at a concert at Mills College in 1972.
Cyxeris
PostPosted: Thu Feb 12, 2004 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
My father has always been a big HAM operator (or whatever the practicioners of HAM radio are called.) For awhile there, I was actually working for my own license, but at the time (somewhere around 8 or 9 or 10), I had no interest in it other than the quality of it being "what my dad does"
Cyx
∆ Cyx ∆
-Napoleon Dynamite
Audio files: 21
PostPosted: Thu Feb 12, 2004 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
WOW! Thst one is really nice!
Flickr
