gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Thu Mar 01, 2007 7:37 am Post subject:
MORE MORPH GROUPS Subject description: Please Clavia HELP US!!!!!!!!!!!!! |
Why not????? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Mar 01, 2007 8:56 am Post subject:
Once Dave Peck suggested an extra Morph using the modulation input to a parameter and a constant module to set the morph value. Using a level scaler one can set the range. It worked in the Classic, so it has to work in the G2!
Wout |
gomidas
G2 patch files: 6
Posted: Thu Mar 01, 2007 12:59 pm Post subject:
Thanks Wout.I will try... |
davep
Joined: Jul 05, 2004 Posts: 467 Location: Oakland, CA
Audio files: 10
G2 patch files: 73
Posted: Tue Mar 06, 2007 11:43 pm Post subject:
Hmmm? Ah yes. On the NM1, I sometimes needed more than the four Morph groups so I created psuedo-morph groups using one Constant module (assigned to a panel knob) to control lots of other parameters. You route the signal from Constant module to various mod inputs, or use it to control VCAs that, in turn, control the levels of various other mod signals going to mod inputs. Use inverters, level scalers, shapers, etc. to alter the response & polarity of the Constant signal as needed on some of the destinations.
Info on this in the archives:
http://nm-archives.electro-music.com/010_NordModular/014_Interesting_Threads/Folder/5thMorphGroup/5thMorphGroup.htm _________________ Dave Peck |
dasz
Joined: Oct 16, 2004 Posts: 1644 Location: victoria, canada
Audio files: 29
G2 patch files: 56
Posted: Fri Mar 09, 2007 6:31 pm Post subject:
and for those parameter who's parameters cannot be modulated (like sequencer levels or eq's you can always route you extra "morph group" or "additional morph parameters" controls mixed with an offset (a 2 mix with your morph as one input and original value as a 2nd input mixed) to a midi cc send internally and map this cc to your desired parameter ...
I rarely need more morph params ...
/Dasz |
hyperstationjr
Joined: Jun 12, 2005 Posts: 111 Location: New Jersey/New York
G2 patch files: 24
Posted: Tue Mar 13, 2007 9:51 pm Post subject:
Couldn't morph groups basically be replaced if they just allowed a Midi CC signal to be sent to multiple sources? Isn't that basically what morph groups do?
I think if they kept the 8 standard morph groups, but added that feature, along with the ability to set range and polarity of MIDI CC's, it would be set, at least on this end... _________________ Studio:
Blokas MidiHub, Clavia Nord Modular G2 Engine, Elektron Analog Four Mk2, Elektron Digitone, Elektron Machinedrum UW+ Mk2, Elektron Octatrack Mk2
For Sale/Trade:
Alesis Microverb 4, Make Noise 0-Coast, Monome Norns Fates clone, Panasonic RQ-705 Reel-to-reel, Roland Alpha Juno1, Yamaha TG55 |
gomidas
G2 patch files: 6
Posted: Sat Mar 17, 2007 6:15 am Post subject:
Hey Hey! I see there's still a lot of thing I must learn about Nord Modulars.
Really, thank you, for ALL THIS TIPS.
GURUS RULES |
