using electronics trainers with modulars?
Page 1 of 1 [10 Posts]
astroid power-up!
PostPosted: Sat Apr 14, 2007 11:59 am    Post subject: using electronics trainers with modulars? Reply with quote  Mark this post and the followings unread
http://www.troper.com/electronics__electricity_training_system
that kind of stuff-trainers with heaps of logic modules and other low-level stuff. what would i need to look out for, patching these through a modular? would it work at all?
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
astroid power-up!
PostPosted: Sat Apr 14, 2007 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.troper.com/modular_electronics_system_trainers
that one in particular
Former site admin
Audio files: 353
PostPosted: Sat Apr 14, 2007 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure sure what you want and/or expect ...
What could kill connected equipment is out of specs voltages on it's inputs. On old modulars gate inputs sometimes have restricted levels 0 .. 5 V, for other inputs a range from -10 to +10 V is usually safe. The kit has the tools to make sure of signal levels.
It's just that I wonder what it would add to a modular system .. in itself.
I see this as a (self) teaching tool, this might of course result in circuits of interest for a synth, and as such I can see use for hooking it up to a synth. I'd expect people to rebuild a found circuit into a more permanant module like thing to be incorporated in the synth then/afterwards.
This moght cost quite some money, but it looks like a useful tool to learn about electronics. It depends a bit on the quality of the instruction material that comes with it.
astroid power-up!
PostPosted: Sat Apr 14, 2007 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, i'm looking for low-level stuff, like logic gates, flipflops, comparators basically all the small stuff that the g2 has. also, having low-level components seems just dead sexy.
i'm a tinkerer at heart, even though i know nothing about anything.
i'm not expecting some crazed sound generators, but more stuff where i can implement little weird kinks and stimulate my imagination.
and, some of these used kits tend to be cheaper, like waaaay cheaper. you might find a kit with 20 logic gates/6 flipflops/etc. for less than 50 bux. if they worked, it'd be a really easy way to put logic into a modular.
mono-poly
PostPosted: Sat Apr 14, 2007 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used to had a big logic one with some other interesting stuff in it.
Like a comparator etc it was a ces ed-lab one.
astroid power-up!
PostPosted: Sat Apr 14, 2007 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
so it worked with modular stuff pretty well?
Former site admin
Audio files: 353
PostPosted: Sat Apr 14, 2007 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, the 2nd link seemed to point to something more analog in nature.
With using logic circuits in a synth you have to take care not to blow the logic's inputs as well. this depends on the logic family used. CMOS circuits could be useful as they could have a supply voltage of 15 Vollt. You'd probably want some protection circuits to make sure that they never see less than zero or more than 15 V in their inputs. For other families the max voltage could be 5 V, not as practical for a modular system.
I looked at some of the logic kits, but could not find what family was used.
Are you sure you don't want to do some soldering yourself ? It wouldn't be too hard ... pick some interesting CMOS gates solder them on perf board together with some protection then add a bunch of of connectors and off you go.
astroid power-up!
PostPosted: Sat Apr 14, 2007 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
well,
i would love to, but 1. i'm totally without any understanding of electricity and 2. i don't have a place to solder. i don't wanna do it in my small apartment, because our ventilation isnt up to snuff.
mono-poly
PostPosted: Sun Apr 15, 2007 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
The ED-Lab worked ok with my Serge.
cebec
G2 patch files: 31
PostPosted: Mon Apr 16, 2007 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, maybe jamos (jim johnson) will stop by but I know he used the ED Labs with his banana-jacked modulars. I've heard that they do work. The Comdyna stuff looks particularly nice, (and works with modulars) but the GP-6 is no longer made.
http://www.comdyna.com/
The CES Ed-Lab's look cool, though!
http://www.cesindustries.com/ces651_y.htm
http://www.cesindustries.com/ces750_y.htm
