Former site admin
Audio files: 353
Posted: Sat Jun 30, 2007 5:14 pm Post subject:
some hacking |
I bought me a new sound card this week, an RME Multiface II. When I had it installed today and after reading the manual a bit I thought this could be my remote matrix mixer as well, a thing I'd been wanting for a while. So I did some coding based on the info I found at : http://home.comcast.net/%7Erobbowers11/MCMap.htm as that's the sort of language the multiface understands.
It's not near anything good yet, but it seems doable. I downloaded MidiYoke to have some patch cords and I fired up my good old NetMidi to be able to do MIDI over TCP/IP. For the remote I wrote a little thingy that sends and receives MIDI over TCP/IP to the distant NetMidi which communicates with MidiYoke, which communicates with the Multiface software. And it works.
Just a few hours of typing and trying really, but I can remotely move my first sliders
This has the potential to grow into a full 8 x 8 cross point mixer, and with the adat extensions it could even be 16 x 16.
The device sounds like a miracle BTW after having lived for nearly a year with all sound running through the built in sound card of the PC, I seem to have 50 dB improvement of signal to nonsense as well, the nonsense used to be at -45, or something that bad. With a bit of tweaking it might be able to do silence
| Proto of multiface remote control |
16.53 KB |
| Viewed: |
789 Time(s) |
Posted: Sat Jun 30, 2007 5:24 pm Post subject:
| Excellent Jan! I was hoping for better Mackie Control support in the G2 (needs pitch bends & such). Maybe your software could have a CC -> pitch bend translation, and all would be well? |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Tue Dec 16, 2008 3:19 pm Post subject:
Jan, can I ask you a few things about the netmidi thingy here? I have an old pc (one with an ancient but nice ISA legacy soundcard that I want to keep using) that is connected via crossover ethernet cable to my main pc. I use remote control software to control the ancient pc from my main pc. Since my main pc uses a wireless lan connection for internet, I have put the ethernet NICs on a different subnet from the wireless lan, in order to use both connections simultaneously without have IE trying to get a connection through the ethernet connection.
Got that ? Now, so far it is working, but now I want to use your netmidi application to link a software's midi in and out on my main pc to the soundcard midi in and out on the ancient one (netmidi + midi yoke should be able to do that, right?) without using a hardware midi interface + midi cables. Well, when I fire up netmidi on both pc's, I see no connection. Could it be that it is trying to communicate through a tcp port on the wrong subnet, since I have these two lans on my main pc? I have little network experience, so forgive me if this is a not-so-bright question . Any suggestions what I could try? _________________ Spinning at ~0.0000115740740741 Hz |
Former site admin
Audio files: 353
Posted: Tue Dec 16, 2008 3:28 pm Post subject:
let me think ... ok 1st things 1st ... I made two things and I mix 'm up all the time ... one is a server only, and it can have multiple clients but it can not connect to another netmidi server. The other was client or server, user selectable, only one connection , but some chat stuff in it ... both are called netmidi I think ... which one do you have? |
Former site admin
Audio files: 353
Posted: Tue Dec 16, 2008 3:33 pm Post subject:
Wait there is a 3rd one, also a server only ... that's the one on my nm open software page ... it says socket error here when I run it on Vista  |
Former site admin
Audio files: 353
Posted: Tue Dec 16, 2008 3:39 pm Post subject:
Oh oh, and 4th M/CP ... help, I don't know what I published where anymore  |
Former site admin
Audio files: 353
Posted: Tue Dec 16, 2008 3:51 pm Post subject:
got it together, sort of ... you need MC/P from here
Copy the exe to both computers, in the settings tab set one to "is server" and the other not (it's a client then). The client one needs an IP address to be filled in and both sides must have the same port setting.
Shouldn't matter how many NICs you have, running "ipconfig /all" from a dos box will tell you what the IPs are for all the NICs you've got. |
Fozzie
G2 patch files: 49
Posted: Wed Dec 17, 2008 5:11 am Post subject:
Ah, thanks a lot (also for understanding my intention ). Will try when I am at home tonight. _________________ Spinning at ~0.0000115740740741 Hz |
Fozzie
G2 patch files: 49
Posted: Sun Dec 28, 2008 9:54 am Post subject:
| Blue Hell wrote: |
A bit late, but thanks a lot, Jan. It works perfectly! Now I *just* need get the other stuff working  _________________ Spinning at ~0.0000115740740741 Hz |
Former site admin
Audio files: 353
Posted: Sun Dec 28, 2008 10:12 am Post subject:
Good in fact .. i had to do a last minute bug fix on it (some settings could not be changed from the program)
So what's the other stuff? |
Fozzie
G2 patch files: 49
Posted: Sun Dec 28, 2008 12:42 pm Post subject:
Ah, well, I got this old Terratec stuff with the microwave pc module, which is a kind of microwave II/XT linked to an old ews64 card. I used to have that in my main PC linked to a newer DMX card from Terratec, but for some technical reason it was not possible to get sysex data out from the module to use with an editor and to edit wavetables. So, I got an old pc with 98se linked via LAN with VNC server/viewer to remote control the thing, so functionally I now have a kind of microwaveII module. However, IIRC you have had the experience as well, the EWS cards are notoriously hard to get set up correctly, so that's the 'other stuff'. I used the old card for many-a-year so I will pull it off, but I have to get back into the subject again. But with your nice app, midiox, midiyoke and some other stuff it will work. I insist and hereby convince myself saying it: *it will work*  _________________ Spinning at ~0.0000115740740741 Hz |
Former site admin
Audio files: 353
Posted: Sun Dec 28, 2008 1:52 pm Post subject:
| Fozzie wrote: | | However, IIRC you have had the experience as well, the EWS cards are notoriously hard to get set up correctly, so that's the 'other stuff'. |
Hmm, yes, it's a bit of a headache thingie isn't it.
| Quote: | *it will work*  |
That's the /only/ to get it to work IIRC  |
