Nord lead 2X power from USA to UK 220V
Page 1 of 1 [2 Posts]
room
PostPosted: Sun Jul 15, 2007 11:50 am    Post subject: Nord lead 2X power from USA to UK 220V Reply with quote  Mark this post and the followings unread
Hi folks - I'm buying a nord lead 2X from the USA to use in the UK.
There is a voltage difference between the maions supplies in these two countries.
What is the best way around this. Does the synth have a switch or will I need a transformer?
Thanks
David
Audiobulb Records : Exploratory Electronic Music
Former site admin
Audio files: 353
PostPosted: Sun Jul 15, 2007 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know for the Nord Lead synths, but the Nord Modulars have either a switch or resolderable jumper for the voltage selection (depending on the exact type), I guess it's the same for the Leads.
When you change the voltage you should also change the fuse, when running on 230 / 240 Volt the current consumed is halved when compared to the 110 V situation, roughly. So the fuse should be half the value a well. Guess you'll have to open the synth on arrival to see what to do, when not sure just ask here, maybe take some pics of the inside.
