Collecting ChucK drum sound designs
Page 2 of 2 [38 Posts]
Goto page: Previous 1, 2
kijjaz
PostPosted: Thu Feb 19, 2009 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh.. thanks, you guys.
Hey I've just listened to the piece. Really nice and funky snare drum pattern. wow wow nice nice.
kijjaz
PostPosted: Thu Feb 19, 2009 10:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
So this is the updated Noise+Sine Bass Drum, Snare Drum, Hi Hat machine
This time, it's a class now, so I guess it's pretty easy to start running.
Here's the source code and test code of the version 0.2 prototype
kjz_BDSDHH-0.2proto.ck
Noise+Sine Bass Drum, Snare Drum, Hi Hat machine ver. 0.2 prototype
 Filename:  kjz_BDSDHH-0.2proto.ck
 Filesize:  5.41 KB
 Downloaded:  1123 Time(s)
Inventor
Audio files: 270
PostPosted: Fri Feb 20, 2009 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you kijjaz, master of ChucK drums! I'm going to put this in my KNoW Wave generator right now.
Inventor
Audio files: 270
PostPosted: Fri Feb 20, 2009 2:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, I'm amazed. I put your drums in the KNoW Wave generator and it is vastly improved, kijjaz. I set it up so that all of the drums have their own logic table and if the bass drum has a hit then it hits. If not, then if the snare drum has a hit then it hits, and so on down the line. This leads to a wonderful variety of drum sounds that are like a real drummer selecting from the set of drums available. Very nice. Thanks, kijjaz!
kijjaz
PostPosted: Sun May 10, 2009 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
another simple quite-analog simple snare drum by Phase Modulating a SinOsc with a filtered noise.
Code:
Phasor a => SinOsc b => ADSR b_env => Dyno compressor => dac;
1 => b.sync;
compressor.compress();
.4 => compressor.thresh;
10::ms => compressor.attackTime;
Noise c => LPF c_f => ADSR c_env => b;
1 => b.gain;
.35 => c.gain;
c_f.set(220 * 12, 2);
220 => a.freq;
1::ms => b_env.attackTime => c_env.attackTime;
150::ms => b_env.decayTime;
120::ms => c_env.decayTime;
0 => b_env.sustainLevel => c_env.sustainLevel;
120::ms => b_env.releaseTime => c_env.releaseTime;
while(true)
    1 => b_env.keyOn => c_env.keyOn;
    500::ms => now;
Hillaby
PostPosted: Sat Oct 31, 2009 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
A quite configurable cymbal sound.
It uses disharmonic sine waves and a "violet noise".
Code:
Noise noz => HPF hpf => ADSR adsr => dac;
.1=>noz.gain;
4000=>hpf.freq;
SinOsc o[10];
hpf.freq()=>float baseFreq;
(7000 - baseFreq) / o.cap()=>float freqDiff;
.2 / o.cap() => float oGain;
for (0 => int i; i <o> adsr;
   baseFreq + i*freqDiff => o[i].freq;
   oGain => o[i].gain;
adsr.set(0::ms, 300::ms, .5, 400::ms);
while (1) {
   adsr.keyOn();
   200::ms => now;
   adsr.keyOff();
   800::ms => now;
Hillaby
(Szilveszter)
More music at ReverbNation
... at MySpace
A humble blog
Hillaby
PostPosted: Sat Oct 31, 2009 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Ooooh, lt signs messed up, next time I'll use preview. So here it is:
Code:
.1=>noz.gain;
4000=>hpf.freq;
SinOsc o[10];
for (0 => int i; i < o.cap(); i++) {
   o[i] => adsr;
   oGain => o[i].gain;
while (1) {
   adsr.keyOn();
   200::ms => now;
   adsr.keyOff();
   800::ms => now;
cbit
PostPosted: Tue Nov 17, 2009 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I expect that kick drums are well represented here already, but here's a simple exponential-pitch-dropping sine kick.
Code:
// Tunable params
360 => float pitchMod;
50 => float pitchBase;
0.0015 => float decayConstant;
400::ms => dur decay;
SinOsc s => ADSR env => dac;
env.set(1::ms, decay, 0.00000001, decay);
fun float expDecay(float x){
   return 1*Math.exp(-decayConstant*x);
fun void pitchDecay(){
   pitchMod+pitchBase => float currFreq;
   for(0 => int i;currFreq>pitchBase;i++){
      currFreq => s.freq;
      1::samp => now;
      (expDecay(i)*pitchMod)+pitchBase => currFreq;
fun void oontz(){
   0 => s.phase;
   spork ~pitchDecay();
   env.keyOn();
   1::ms=>now;
   env.keyOff();
while(true){
   oontz();
   if(maybe){
      1::second => now;
   } else {
      0.25::second => now;
http://basementhum.blogspot.com
kijjaz
PostPosted: Wed Nov 18, 2009 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
yesterday i was listening to a Minimal Techno artist "Nolens.Volens" live here, i really love the bass sounds. will study how to combine signals to create that kinda rich bass drum sound.
Inventor
Audio files: 270
PostPosted: Wed Nov 18, 2009 9:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice work guys, I want to work with your code as soon as I get time. Keep on ChucKin'
Les
AllTom
PostPosted: Sun Feb 07, 2010 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
kijjaz: awesome
Inventor
Audio files: 270
PostPosted: Sun Feb 07, 2010 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
AllTom wrote:
kijjaz: awesome
Welcome to the forum, AllTom. I've seen some of your posts to the ChucK users group list.
Les
gadu
PostPosted: Wed Mar 18, 2015 11:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
All of you making a great work.
-_-
"The old computing is about what computers can do. The new computing is about what people can do."
Ben Shneiderman
