Sub osc??
Page 1 of 1 [4 Posts]
illiac
PostPosted: Thu Jan 17, 2008 3:47 pm    Post subject: Sub osc?? Reply with quote  Mark this post and the followings unread
Hey everyone! first post here.
I'm putting together my first eurorack and am still deliberating over most of my selection...
What looks definite though is a Cwejman vco 2rm dual oscillator.
What I want to achieve is a 2 osc synth with a sub oscillator (sh-101 style)
but I'm not sure what i need. Can 1 of the osc's in the cwejman function as a sub? Should I look for an audible lfo?
Sorry if it's come up already, couldn't find anything on the subject.
Thanks!!
REwire
PostPosted: Thu Jan 17, 2008 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cwejman's OSC's can drop down to sub levels as they have a wide range and LFO Switches. You can also run one into an audio divider if you want to achieve a sub without losing one osc. Only problem with the VCO-2RM is that it does not have individual outputs for the waveforms so you'd have to split the signal. Cwejman is coming out with a new single Osc with individual outs and some new thicker waveforms.
http://www.REwireMusic.com
Buy REwire - "Bit By Bit" CD at http://cdbaby.com/cd/rewire
Album Promo Video:HERE
Per
PostPosted: Sat Jan 19, 2008 3:47 am    Post subject: Reply with quote  Mark this post and the followings unread
The Cwejman dual VCO sounds great, but are expensive, and you might want the two VCOs for more advanced missions than just a sub VCO.
The classic sub VCO sound is an octave divider.The Doepfer A-115 is a cheap one. More fun and powerful is the Blacet Binary Zone, but then you have to add a Blacet Frack Rack to your rig.
If you have enough money, my advice is to add a cheap Analogue Solution or Doepfer VCO. Properly tuned and in hard sync, it works like a sub VCO. But it can also add some real fatness to any sound.
Good VC LFOs that track the 1 v/octave scale is just the same as a good VCO, and that increases the cost. The Cwejman dual VCO and dual LFO is more or less the same core electronics.
Per
morbius
PostPosted: Sat Mar 15, 2008 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I dunno if this is something that would be compatible with your needs... but- just so you know, I have two Synthesizers.com modular systems... and I have successfully taken the Q106 osc. down to somewhere near 1 cycle : 20 (or so) hours. yeah... that's right. So low, that it's impractical to record as a demo or 'proof' (if you will).
Using the Q125 Signal Processor patches to the Q106's 'linear' input, I started the cycle, and over ten hours later, it STILL had not come close to finishing one cycle. Of course, the most obvious question... what practical purpose does such a low frequency serve? I dunno. I just wanted to see what was possible, since a couple of people complained, saying that Synth-dot-com doesn't offer an LFO. As the developer, Roger Arrick has said, why make a deditcated LFO, when the Q106 will do that... and so much more (perhaps cost is what some look at). But at less that $200... with all the trimmings, waveforms, sync, and Calibrated Range Switches... it'll do much for you.... and, it is stable, stable, STABLE! No drift... AT ALL.
~Morbius~
New CD "Remembering Tomorrow" soon to be released (wild with analog-modular and digital synths).
~Morbius~
http://www.MusicByCybertron.com
morbius001a@yahoo.com
