Expression pedal how to
Page 1 of 1 [4 Posts]
fischek
PostPosted: Tue Feb 05, 2008 7:33 am    Post subject: Expression pedal how to Reply with quote  Mark this post and the followings unread
hi,
I've tried using the expression pedal yesterday for the first time (actually used my Korg damper pedal - is this a proper pedal for this function?). Everything was fine except that I wasn't able to figure out if it's possible to change the direction of the expression the other way around.
For example, open the filter when you press the pedal and close it when you release it. Is it possible to toggle this so that it's reversed? Thanks!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Feb 05, 2008 9:03 am    Post subject: Re: Expression pedal how to Reply with quote  Mark this post and the followings unread
fischek wrote:
... Is it possible to toggle this so that it's reversed? ...
Yes, you can... Only... I think you are using a Sustain Pedal in the Control Input. If you use the pedal in the Sustain Input, you can change the polarity at [Shift+System > change SPO into SP1]
You'll need a Control Pedal in that input, like the one's you can use as a swell pedal in many an organ.
Even much nicer, a pressing sensitive resistor!!!
Wout
fischek
PostPosted: Tue Feb 05, 2008 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Wout!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Feb 05, 2008 12:23 pm    Post subject: Re: Expression pedal how to Reply with quote  Mark this post and the followings unread
A pressure sensitive resistor is a momentary switch, instead of the Wheel, which keeps its value when set. The resistor always returns to its zero position. Another nice thing is the resistor reacts of the players 'musculus' tension, so an active playing device.
Just solder to a cable and the 6.3 jack, insert it in the Control Input and mount it using cello-tape beneath the Wheel or somewhere else.
The whole idea is by Rob Hordijk.
Wout
 Filesize:  9.28 KB
 Viewed:  3941 Time(s)
