recording tweaks to more than one drum sound on drum patch
Page 1 of 1 [2 Posts]
intellijel
PostPosted: Sun Feb 10, 2008 10:52 am    Post subject: recording tweaks to more than one drum sound on drum patch Reply with quote  Mark this post and the followings unread
ok another thing I have been trying to figure out but I assume is impossible:
In drum mode you can edit a drum sound if you press a black key first in that drum sounds zone first.
My question is this: If I am recording this to a sequencer, is it possible to record the real time tweaks or more than one drum sound? It seems impossible because you would have to have the appropriate black key triggered before each set of CC data is sent back from the sequencer.
Any tricks or workarounds? It would be so powerful to be able to have realtime CC control of more than one drum sound in a drum patch. (Autechre anyone?)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Feb 10, 2008 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
If your not using the same CC, like the Cut-off, for more then one sound... It should work, at least in my CuBase version (1.10) it works, although you has to have it right in trhe first run, because you can't use the replace feature. So save everything which is right and by mistakes close and open again...
Wout
