Physical Models
Page 4 of 4 [99 Posts]
Former site admin
Audio files: 353
PostPosted: Sun Nov 07, 2010 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice demo Scott - I like these sounds!
JovianPyx
Audio files: 237
PostPosted: Thu Jan 13, 2011 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've made progress with a new project, a flute model based pipe organ, 16 flute models that run in parallel. I finally got the 16 voice MIDI controller to work properly. No sound yet, lots of work still to do - mostly getting the patch editor to send separate flute pipe parameters to each pipe. I have 4 boards that this will run on, so potentially 64 pipes if the thing actually works.
I found a way to speed up slow pipes Razz
EDIT ADDED 2011-01-21:
Fixed broken ADSR, fixed numerous "it ain't gonna work like that" things. I get sound, but it isn't right.
Time flies like a banana.
corruptio optimi pessima
JovianPyx
Audio files: 237
PostPosted: Tue Jan 25, 2011 6:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh boy - sound - not totally right, but way better.
Not sure yet why this mattered, but I had been using a single port RAM to implement the bore and jet waveguide delay lines. I decided to try a dual port RAM and see what would happen. Well, now, I _can_ get a flute sound, but it's weird what I have to do to get it... I have to hit many keys, and I can hear lots of pipes starting up and then there's distortion, but if I pick one of the keys I hit and hold it while releasing the others, I hear an obvious flute pipe. So I still have some work to do but apparently, the design likes a dual ported RAM... Smells like a timing problem...
This is not a plea for help, just venting my frustration and exclaiming my glee that now at least it appears I'm close to a flute-pipe organ.
JovianPyx
Audio files: 237
PostPosted: Thu Jan 27, 2011 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
The timing issue is resolved, the proper ADSR now turns on when keys are pressed. I get polyphonic flute-organ sounds now.
Next step is to "tune" the pipes - they are already correctly tuned for pitch, but need enhancement to get them resonating faster. The enhancement is built into the design, but it needs to be configured individually for each pipe. I will also try lowering the sample rate from 100KHz to 50KHz to get sounds an octave lower.
I should have some sounds rather soon.
JLS
G2 patch files: 316
PostPosted: Wed Mar 02, 2011 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Scott
PhLUTe sound demo is very nice is possible post source code for Spartan-3E ?
Many thanks
https://www.youtube.com/@kamilondrousek6973
https://soundcloud.com/1jls
https://soundcloud.com/user-819966312-266044932
https://github.com/jlswbs
https://www.instagram.com/ondrousek.kamil/
JovianPyx
Audio files: 237
PostPosted: Wed Mar 02, 2011 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
JLS wrote:
Hi Scott
Many thanks
Well, I'm not even close to satisfied with it. The startup time for a pipe is still too long and improving it at all is a very tedious task of parameter adjustment. This is the third time I've revisited this issue, so in a word, I'm not proud it at all.
Neither the phLUTe nor the Pan_phLUTe are working to my satisfaction, which is why I haven't produced any music with it.
The phLUTe (not Pan) also suffers from a problem documented by Perry Cook, that being when the bore length is changed to change the pitch of the instrument, a transient is introduced that sounds very unnatural. The Pan_phLUTe is made of several pipes, where the length remains constant and it is intended to be played like an organ - but the startup time is still an issue, though somewhat better, but still too long to be musically useful (in my opinion).
I have scoured the internet to see if anyone else has been able to fix these problems, but I've found nothing.
The design is being developed on the Spartan-3E board... Just not ready for "prime time". -- I know -- Sad
I've also been considering another way to synthesize a flute sound which is far more common and would be much easier to implement - that would be a simple additive synth that uses sine waves. A flute produces at most 3 harmonics (a fundamental, octave above, octave+5th above and 2 octaves above). This would easily fit in the Spartan-3E but would require research into how flutes tone evolves from startup to steady state and to simulate overblow and "airy" quality by including white noise, possible passed through a bandpass filter like my tonal noise synth.
JLS
G2 patch files: 316
PostPosted: Wed Mar 02, 2011 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks info Scott Smile
I not musician but only miscellaneous sound synthesis and structures very interesting me.
Very thanks all yours future code projects Smile
JovianPyx
Audio files: 237
PostPosted: Tue Aug 30, 2011 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have worked out some math and did some test trials of a "new" idea.
I wanted to see if I could use one of my smaller FPGAs to make a Karplus-Strong harp. The current instrument I have for the Spartan-3E Starter Kit plays only in 8 note polyphony.
This is not new - but it is new for me in terms of making an implementation that is well tuned and doesn't suffer from noticable timbre change from string to string.
My previous attempts at Karplus-Strong systems have always been with integer length waveguides. I have now tested a new system that uses a much lower sample rate than previous designs - 48.0 kHz as opposed to 820 kHz. The lower sample rate allows the waveguides for a given pitch to be much shorter - but as I discovered in earlier experiments, the accuracy of tuning becomes problematic as the waveguide length is made shorter. Shorter string lengths means more will fit into a given amount of RAM.
To compensate for that, I included a fractional delay filter or a first order LaGrange interpolator. This is a tiny FIR filter (kernel length = 2), where the kernel parameters are used to interpolate over a one sample length time frame. This has allowed far greater tuning accuracy using much shorter waveguides than when integer lengths are used. I calculate that I can get 60 strings out of a Spartan-3E Starter Kit FPGA - that's 60 string that can all resonate at once - meaning the synth will be not 8 note poly, but rather 60 note polyphonic.
Internally, the design will have a structure similar to Xarp-56 (and I may limit the design to 56 strings to make it easier to use the Xarp-56 code).
The waveguides will consume 18 of the 20 block RAMs.
My tests included listening comparison between the plucked waveguide output and a sinewave of the concert tuned pitch. The system does very well and there is no in-your-face "hey - that string sounds different" thing.
The instrument's fundamental frequency range will be from 46.249 Hz to 1396.913 Hz.
Dougster
PostPosted: Tue Aug 30, 2011 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hope I'm not picking nits, but do you mean 48 kHz instead of 48000 kHz?
Once you start down the modular path, forever will it dominate your destiny!
Every DIY person should own a copy of Electronotes: http://electronotes.netfirms.com
Blue LEDs are evil.
JovianPyx
Audio files: 237
PostPosted: Tue Aug 30, 2011 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quite correct oh Dougster with the Eagle-Eyes... Smile
JovianPyx
Audio files: 237
PostPosted: Tue Aug 30, 2011 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, sound file is probably necessary.
This is a downward chromatic scale through the instrument's entire range. The sample was made using a C program that implements the idea.
I like the gut-string sound I get from this.
The clicks at the ends of some of the lower notes are from the naive EG I implemented. (you know, this was a test, not a compostition... Smile )
Spartan-3E_Xarp_Idea_Sound_File.mp3
Chromatic scale sample
 Filesize:  2.33 MB
 Duration: 2:32
 Viewed:  4373 Time(s)
JovianPyx
Audio files: 237
PostPosted: Mon Sep 05, 2011 8:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a working Spartan-3E (500) design.
It has 61 strings and uses fractional delay filters for fine tuning the waveguide lengths.
The fractional delay filters I used are first order lagrange interpolators. This is a filter (FIR lowpass, kernel length=2), but it also interpolates between the last and second to last elements of the delay line.
JovianPyx
Audio files: 237
PostPosted: Tue Sep 06, 2011 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a chromatic scale demo with the current hardware. Sustain is down. Mod wheel is at maximum (meaning minimum integrator leakage) and maximum sustain.
xarp_61_chromatic_demo.mp3
Xarp chromatic scale demo
 Filesize:  168.24 KB
 Duration: 0:11
 Viewed:  4309 Time(s)
JovianPyx
Audio files: 237
PostPosted: Wed Sep 07, 2011 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a short piece of music using only the Xarp for Spartan-3E.
Accretion.mp3
Accretion
 Filesize:  1.55 MB
 Duration: 1:41
 Viewed:  4213 Time(s)
JovianPyx
Audio files: 237
PostPosted: Wed Sep 07, 2011 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Since I have 4 of these boards, I decided to try something ... I used two boards and detuned them from each other by changeing the sample rate slightly. The result is interesting in my opinion. The piece is the same sequence. One is panned left, one is panned right.
This was just for fun, so please enjoy!
Accretion_Dual_Xarp-61.mp3
Accretion - using two Xarp-61 instruments, in stereo.
 Filesize:  1.57 MB
 Duration: 1:43
 Viewed:  4187 Time(s)
PostPosted: Thu Sep 08, 2011 2:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was just comparing these latest to some of your earliest uploads, and these sound really great. It's great to see this coming from FPGAs!!
JovianPyx
Audio files: 237
PostPosted: Sat Sep 10, 2011 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks JK... But I'm sad to say that the instrument is flawed. There's a pitch bug at least and I've got improvements I'm adding.
I will post a ver_e that will contain corrections and additions.
The pitch bug causes notes to be sharp as one goes up the scale.
There is also a pitch ROM data problem that causes the lowest C key to play a C# with that error carried up through the note range.
Lastly, the lowest octave is practically useless.
ver_e will correct the above problems and I will be doubling the sample rate to 96 kHz using some parallelism. This will put the range of the instrument in a more useful place.
Dan Lavin
Audio files: 21
PostPosted: Sat Sep 10, 2011 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott, even flawed this sounds wonderful!
Synth DIY since 1977!
JovianPyx
Audio files: 237
PostPosted: Sat Sep 10, 2011 10:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I fixed the problems in Xarp-61 and I'm posting a new demo - it has a few more notes but is basically the same.
I'm too tired to put the ver_e source up... that will happen tomorrow.
Accretion_Dual_Xarp-61_2.mp3
"Accretion" played on 2 slightly detuned Xarp-61 instruments
 Filesize:  1.73 MB
 Duration: 1:53
 Viewed:  4233 Time(s)
JovianPyx
Audio files: 237
PostPosted: Sun Sep 11, 2011 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
ver_e source code is available at:
http://jovianpyx.dyndns.org:8080/public/FPGA_synth/Xarp-61.html
The improvements were made in the form of bug fixes and a redesign of the instrument's internal structure. The previous version implemented a single 61 string harp processed at 48 kHz sample rate. Reorganization of RAM resources as dual ported RAM allowed for a 2 harp system with the harps operating in parallel. This allowed for an increase in sample rate to 96 kHz and a rise in pitch of exactly one octave.
EDIT ADD: The code package also contains a VB.NET (Express Edition) project for the patch editor (which is required). Note that the patch editor was created by modifying another patch editor and there are tabs and functions that do nothing. The first two tabs work, and in the last tab, the MIDI channel control works. Sorry - I threw it together...
richardc64
Audio files: 26
PostPosted: Sun Sep 11, 2011 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't understand much of this thread, but I can recognize a great tune when I hear one! banana
JovianPyx
Audio files: 237
PostPosted: Sun Sep 11, 2011 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why thank you richardc64!
and btw - I love your avatar image.
JovianPyx
Audio files: 237
PostPosted: Sun Nov 06, 2011 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Xarp-61 for the Spartan-3E Starter Kit board now has DDR SDRAM used for looped delay effect.
JovianPyx
Audio files: 237
PostPosted: Mon Apr 09, 2012 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've revisited an older physical model design - PolyDaWG-8 - an 8 voice Karplus-Strong synthesizer on a Spartan-3E Start Kit Board.
This instrument is 8 voice polyphonic implementing 8 variable length Karplus-Strong strings.
The "strings" are digital waveguides - digital delay lines fed to a simple lowpass filter and then back into the input of the delay line. There are no oscillators or envelope generators in this synthesizer. All of the amplitude and timbre dynamics occur as a natural result of the mathematics (arithmetic really) involved.
The original design came into being well before I knew how to connect to the DDR SDRAM on the board. The demo attached uses 2 of these synths and each has the DDR SDRAM implementing echo/delay (very short duration in the demo).
The two instruments are tuned slightly differently, so you will hear the phasing between them (in stereo). The demo tune is basically the same one I used for this instrument earlier, but I've enhanced the piece a bit.
I plan to attempt something like this in a dsPIC (actually, more than one).
PolyDaWG8-4.flac
PolyDaWG-8 Demo using two instruments tuned slightly differently and in stereo
 Filesize:  6.58 MB
 Duration: 1:18
 Viewed:  4242 Time(s)
