Lamiaz
Joined: Mar 03, 2008 Posts: 1 Location: United Kingdom
Posted: Mon Mar 03, 2008 6:27 am Post subject:
Nord Lead 2x volume problems |
I recently bought a Nord Lead 2x and have found that there are a number of variations in volume between various pre-programmed sounds, with some being noticeably louder/quieter than others...
Does anyone know if there is a way to set the Nord up so that each sound plays at the SAME volume level? Thanks |
Atlas5
Posted: Mon Mar 03, 2008 8:00 am Post subject:
yeh, I've had the Nord Lead 2X for 4 days now..
I've notice the same thing. So far I only know to adjust the master volume. I assume you would have to tweek the program and then save it.
Other thing, while running scales at the same as changing programs the keyboard, the thing wacked out........started makeing strange sounds, regardless of program or mode changes. I cycled the power and all is fine.
Sure do like the way this keyboard sounds and the control you get from the various switchs & knobs. This is a great addition to all the romplers I have. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Mar 03, 2008 10:29 am Post subject:
Re: Nord Lead 2x volume problems |
| Lamiaz wrote: | | ... Does anyone know if there is a way to set the Nord up so that each sound plays at the SAME volume level? ... | In my published Programs I always set the Gain (most in the upper left knob) at the level 90. Using it in combination in Layers and Performances there is some room to adjust it to each other. When the level is completely up (127) it doesn't match so easily.
The differences are made by using BPF or HPF. Just Change the Filter mode in a Program, and you'll notice the BPF is much less in volume then the Notch+LPF This is normal on a synthesizer.
| Atlas5 wrote: | | ... Other thing, while running scales at the same as changing programs the keyboard, the thing wacked out........started makeing strange sounds, regardless of program or mode changes. I cycled the power and all is fine. ... | What do you mean exactly? 'Running scales' you're are playing a scale (like G major) and make a ProgramChange at the same time, the synth crashes? It could be, because the NL2(X) is very sensitive toward a large amount of Midi information.
Wout |
Atlas5
Posted: Mon Mar 03, 2008 4:16 pm Post subject:
Remove the question marks are you've got it. I believe you are correct on the asumption of MIDI overload. I found this in the manual......if there is a next time I will hit the "PANIC" button and see if the remedies the problem. |
