Joined: Feb 29, 2004 Posts: 2924 Location: Up in that tree over there.
Posted: Fri Aug 06, 2004 3:14 pm Post subject:
I see I got a permission! Thanks!
Here is a composition running < 49 seconds done partly as a "What can ya do with this thing?" experiment. The song is intended to be the last in a set of songs, the first of which uses the same text as in this one but given a very different treatment.
The text by Edward Lear:
"I knew a man who had a plan to dye his whiskers green but always use so large a fan they never could be seen."
I should say that I consider these songs to be compositional lighter works even if when the subject matter becomes rather dark.
Anyway here's a sample of one kind of thing ya can do with a Roland variOS.
IKnewAMan.mp3
Filesize:
744.54 KB
Duration:
0:48
Viewed:
2226 Time(s)
_________________ The question is not whether they can talk or reason, but whether they can suffer. -- Jeremy Bentham
What is this varios thing .. I am not sure I am getting it _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Posted: Fri Aug 06, 2004 4:08 pm Post subject:
It takes audio file data input and creates a digital abstraction of the data that separates out time, pitch, and timbre. To create the vocal for the Lear piece I sang (and I flat out can't sing) a different version of the song. Then did a number on it with autoTune* then loaded it into the variOS which allowed me to play the song on the keyboard using "new" notes while preserving some (analog) of the timber and expression of the original.
Edit
*pre-processing with autoTune is optional depending on your intended use and intonation. _________________ The question is not whether they can talk or reason, but whether they can suffer. -- Jeremy Bentham
WOW!!!!!!!!!!!!! _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Posted: Fri Aug 06, 2004 5:36 pm Post subject:
elektro80 wrote:
WOW!!!!!!!!!!!!!
Well, I did say it creates an "analog" of the original time/pitch/timbre data. Faithfulness to original timbre is not its strong suit. But it is a lot of fun and a great toy. Though a rather specialized one. And as to wether or not it earns its keep in the studio...that's open to debate.
It is used with computer software interface that includes facilities to use the variOS as a dedicated groove/loop composition tool.
It also comes with some fairly crude virtual synths. _________________ The question is not whether they can talk or reason, but whether they can suffer. -- Jeremy Bentham
