 Forum index » Clavia Nord Modular » G2 Patches - Completed » External Control
Waldorf Blofeld Control + Mutator
Page 1 of 1 [2 Posts]
darinm
PostPosted: Fri Jul 04, 2008 1:23 am    Post subject: Waldorf Blofeld Control + Mutator Reply with quote  Mark this post and the followings unread
Hi All,
I'm new around these parts, having just picked up a new G2 a couple of days ago. I really love this thing and have so far found these forums to be an excellent resource with some really cool user patches.
I made a quick patch to gain some familiarity with controlling my external gear with the G2 and thought I'd post it here since maybe someone else will find it useful too.
This is something for Waldorf's new little white beast, the Blofeld Twisted Evil
This patch lets you control just about all of the stuff accessible via MIDI CCs on the Blofeld. This actually covers most of the important functionality of the Blofeld, although some things like controlling the type of drive curve for the filters currently cannot be done with MIDI CCs. I may try to extend the patch somehow for use with a MIDI translator to work around this, but I haven't had time to explore that avenue yet.
Mutator works great with this thing and most of the parameters are included by default, except for some things like noise and ringmod. You can enable them yourself if you like.
In the G2 editor, I've split the modules across the VA and FX section simply for organizational purposes. The VA section has all of the modules that correspond to labeled functionality on the front of the Blofeld. Other extended functionality for particular sections are stored below in the FX section. This is just to make the most important stuff visible up top.
I've also assigned most of the parameters to the knobs on the G2 for convenience.
Have fun Smile
Blofeld Ctl Mut.pch2
Control + Mutation for the Waldorf Blofeld
 Filename:  Blofeld Ctl Mut.pch2
 Filesize:  6.53 KB
 Downloaded:  2084 Time(s)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Nov 23, 2009 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I put some effort in mapping the waveform names, octaves, and some custom grouping of parameters for the filters (see panel D1, with a common Filter1/2 Cut off, Res, FEnv, Env, FAtack,Decay, Sustain, Common/Dual toggle between the common controls on the g2 panel and individual F1 & F2 filter settings).
Works on the same channel as your g2 keyboard. input 3 mapped to take Blofeld audio.
I used darinm's mapping as the source of the assignments.
enjoy. I hope you find it useful.
/Dasz
waldorfBlofeldG2.pch2
easier to read g2 panel mapper (3 osc mapped, including waveform names, octave setting switch, with a common - F1/2 Cut off, Res, FEnv, Env, FAtack,Decay,Sustain, Common/Dual toggle on Panel D-1)
 Filename:  waldorfBlofeldG2.pch2
 Filesize:  10.63 KB
 Downloaded:  2464 Time(s)
