Nordlead 2x and waldorf rack
Page 1 of 1 [7 Posts]
sentokan
PostPosted: Mon Aug 11, 2008 7:29 am    Post subject: Nordlead 2x and waldorf rack Reply with quote  Mark this post and the followings unread
Hi guys!
I have this problem: I have a Waldorf MicroQ rack which has 16 parts; I want to play some parts(sounds) using the keyboard of my beloved NordLead and the rest to be played be a sequencer.
So, I set it up as follows: midi out of the sequencer to midi in of nordlead, midi out of the nordlead to midi in of the waldorf rack.
Unfortunatelly it doesn't work. Can't nordlead use the midi out as a midi thru(merge)?
Thank you all!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Aug 11, 2008 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed, the NL2 has no Midi Through, which isn't a merger, BTW
You'll need a merger, for sure, if you want your set-up to look like 'some sounds to be controlled by the NL-Keyboard and some other sounds by the sequencer'.
Even if the NL had a Midi Through it would send the MidiNotes info using the MidiOut, not using the Through, so a merger is needed.
Wout
sentokan
PostPosted: Mon Aug 11, 2008 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks man! u know there are synths which can do the job without merger, like novation x station? cause I was gonna buy one.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Aug 11, 2008 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Novation X Station is a Midi Controller with a synth build in.
Read the Manual carefully:
http://www.novationmusic.com./support/files/xstation/22/X-Station%20User%20Guide%20-%20English.pdf
Wout
sentokan
PostPosted: Tue Aug 12, 2008 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I know, but doesn t have the abiliyt to merge too,? From what I read in the manual it does, just don't have enough experience with these things to know for sure. Maybe u can take a look.
Thanks so much!!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Aug 12, 2008 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
As far as I know it has the capability to merge Midi signals, but please don't nail me down to it Smile At least the Manual shows us it can...
Manual Novation X Station [Page 12 - Midi Out] wrote:
These can transmit any MIDI information which might be generated by the X-Station. For example, if a note was played on the X-Station keyboard or one of the controls were moved on the front panel. This MIDI information is intelligently merged with any MIDI being re-transmitted after arriving at the MIDI IN / USB ports.
I never worked with an X Station, so I don't take any responsibilities if it doesn't merge... Smile
Wout
sentokan
PostPosted: Tue Aug 12, 2008 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot ! U really been helpful. I appreciate a lot Wink
