3rd run of PCBs for the PS3100 Resonators & the X-panfader
Page 11 of 14 [349 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12, 13, 14 Next
LektroiD
PostPosted: Mon Jun 15, 2009 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
today i put trimmers to a blank x-panner board. took me just a view minutes (no unsoldering necessary).
i shot a view pictures and will amend the documentation this week to make it more clear. but since the pictures are already taken i thought i could post them anyways...
BTW go to the flickR set and you will see the description for each picture.
That's very clear. Good job I never started assembling my second board yet.
I have a question though. I have a big pile of 10KΩ multiturn trimmers. Is it possible to use these instead of the 50KΩ by increasing the value of the fixed resistors to say, 82KΩ. Would that work?
LektroiD
PostPosted: Mon Jun 22, 2009 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
ooops, missed that one! sorry.
i would just try the 10k. however, i did not try it. maybe i will be able to test it in a spice model this week!? i don't want to commit myself to that, though.
anyway, i finaly amended the documentation. below you will find a link to the new complete documentation (4MB) and a 2nd link to the trimmer mod documentation only:
http://www.modular.fonik.de/pdf/PS3100_DT_v3.pdf
http://www.modular.fonik.de/pdf/x-pan_trimmer_mod.pdf
Posted Image
delayed
PostPosted: Mon Jun 22, 2009 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
is the only change to the docs the trimmer mod?
robotfunk
PostPosted: Mon Jun 22, 2009 11:17 am    Post subject: which caps to use? Reply with quote  Mark this post and the followings unread
Hi, I got these boards through a friend, and I must say they look great!
Being a bit of a noob, I am wondering what kind of capacitators to use, since there are so many types available. I have a bunch of bog-standard ceramics and electrolytes, are these OK to use? My friend tells me its important to get the best possible, which did you use? I see on the PCB only a few caps have a + marking, and the rest don't. Does that mean the ones w/o marking are without polarity, and I need to use the ceramics for them?
thanks in advance,
Jilt van Moorst
PostPosted: Mon Jun 22, 2009 11:57 am    Post subject: Re: which caps to use? Reply with quote  Mark this post and the followings unread
different types of capacitors may influence the sound of a module. i never took care about that much. who says what sounds good and what not? noise be another issue, i did not care about that much, too. timing capacitors for LFOs, VCOs or S/H are another story.
however, i use mainly polyester film for almost all purposes. for bypass i use ceramic multilayer or monolithic, what i have on hand.
there are people with much more experience and knowledge here, who might chime in!?
anyways, here is an article by h. bissell about capacitors:
http://www.modular.fonik.de/files/capacitors_101.pdf
yes.
happy building and let us know about your progress.
BTW there is quite a lot valuable info at ray wilsons site www.musicfromouterspace.com with general guidelines about troubleshooting, some very nice tools, explanations ans so on...[/url]
Posted Image
Funky40
G2 patch files: 5
PostPosted: Mon Jun 22, 2009 1:01 pm    Post subject: Re: which caps to use? Reply with quote  Mark this post and the followings unread
thanks in advance,
Jilt van Moorst
where you have the +marking you _must_ take polarized electrolytics, yes. And watch polarisation Wink
The others are unpolarized. common is to use polyesterfilm ( MKS2 )
depending on the function you can take whatever you have or should take a certain type.
when nothing is stated MKS2 is allways a good choice. ( the 2 stands for the spacing = 5mm )
robotfunk
PostPosted: Tue Jun 23, 2009 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks guys
I decided I'll just wing it for now with what I have, can always upgrade later if I don't like the sound, just too eager to get this working Smile (yes I'll mind the polarity of the other caps)
On the resonators board I've got all the resistors in place except the 200k one which isn't in any of my 'standard packages' and all non-polarized caps plus all the IC feet, so I feel I'm halfway, waiting on the vactrols and other parts to finish this one, with my new temp controlled soldering station it goes much faster than before!
Re vactrols, with all this talk about matching vactrol pairs it seems crazy not to go with a dual vactrol, since they are only one dollar/euro more than the single ones, am I right in assuming/hoping they would be somehow matched to each other?
I'll let you know my progress
TekniK
PostPosted: Fri Jul 10, 2009 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Panels
ericcoleridge
PostPosted: Fri Jul 10, 2009 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
Zabalagamanajabagaza?
Wow, these are really impressive panels. How do you get the white print onto black panel? Must be screen print, no?
PostPosted: Fri Jul 10, 2009 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
wow!
realy impressive! amazing. great design. i am speechless for the moment.
Posted Image
TekniK
PostPosted: Fri Jul 10, 2009 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
its laser engraving on black anodized aluminium
diablojoy
PostPosted: Fri Jul 10, 2009 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
if any xpan boards are still remaining will take 2 please
kitsch-bent
PostPosted: Tue Jul 14, 2009 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm really really interested in 4 X-Panner boards....
so, if they are available, count me in Smile
TekniK
PostPosted: Wed Aug 05, 2009 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
panafonik idea:
Junk Rhythm
PostPosted: Wed Aug 05, 2009 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
The SSM2040 and PS3100 panels are beautiful TekniK. Great work.
[twitter] [blog] [flickr] [toppobrillo] [buzz]
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
adambee7
PostPosted: Wed Aug 19, 2009 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
hi matthias.
On the resonator boards. On C18,19,20 can polystyrene be used as i've noticed different spacings on the board?? I was thinking that these were the main filter caps?? Very Happy Very Happy
PostPosted: Wed Aug 19, 2009 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
adambee7 wrote:
hi matthias.
true. for one board i used silver mica, rated for 500V. they needed the large spacing and wider holes...
Posted Image
adambee7
PostPosted: Wed Aug 19, 2009 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
nice one. Micas i've used for other filters i've built. Thanks man. Very Happy Very Happy
de_engineered
PostPosted: Fri Sep 11, 2009 12:27 pm    Post subject: 2 Questions Reply with quote  Mark this post and the followings unread
Quick transistor question: can the BC550s and BC560s be swapped with 2N3904s and 2N3906s? They're just acting as expo converters, right?
Secondly, I got thinking that while these filters are called "Resonators," where's the resonance control?
I'm still waiting one some parts to arrive to finish my pair of Resonators, otherwise I'd have tried myself already: could one add resonance loops to the filter channels? I don't know if the filter topology permits this or not. Something like an electrolytic cap and resistor (maybe a VC element later if this works), tapped from R6, 7, or 8, back to J5 audio in?
de_sign : de_stroy : de_engineered
TekniK
PostPosted: Fri Sep 11, 2009 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
One of my 5 fonik resonators
PostPosted: Sat Sep 12, 2009 2:12 pm    Post subject: Re: 2 Questions Reply with quote  Mark this post and the followings unread
yes. take care of the pinout.
i thought it is called resonator because it can be used to emphasize certain frequencies in order to simulate the resonances of accoustic instruments, stringed instruments in this case. but that's jsut what i thought. maybe i am wrong.
why not. just try and tell us your findings. would be a great mod.
Posted Image
LektroiD
PostPosted: Sun Sep 13, 2009 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm having a hard time getting hold of the vactrols for this in the UK (VTL5C3/2). I can get them at RS components, but they're US stock and the postage becomes outrageous. If anyone knows of a UK stockist of these, please let me know. Even an EU stockist would be a consideration.
LektroiD
gwaidan
PostPosted: Sun Sep 13, 2009 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Might be worth getting it from Smallbear or Bridechamber in the US...their postage aint too bad!
PostPosted: Sun Sep 13, 2009 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
you can get them here:
http://www.musikding.de/advanced_search_result.php?keywords=VTL5C3%2F2
Posted Image
adambee7
PostPosted: Sun Sep 13, 2009 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Banzai in Germany have them i think. I got my singles from there. I have not got mine yet but i'm sure banzai sell them. Very Happy
