How is this done?
Page 1 of 1 [6 Posts]
edjwise
PostPosted: Sat Oct 25, 2008 7:06 pm    Post subject: How is this done? Reply with quote  Mark this post and the followings unread
Does anyone have any patch details about this post?
http://matrixsynth.blogspot.com/2008/08/nord-lead-1-arp.html
Sync + FM?
their is a lot going on in the video, but any ideas as to what the patch configuration is would be awesome
I dont own a nordlead so I wanted to do similar stuff on my other synths.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Oct 25, 2008 11:39 pm    Post subject: Re: How is this done? Reply with quote  Mark this post and the followings unread
Sync + FM?
Surely! Smile
The Patch itself is fixed, of course. The NordLead is a pre-patched synth. Only the parameters differ in each Program.
The Nordlead has 4 Slots, which the artist uses all, so basically you hear 4 synths at the same time. To control these in one movement the Morph function is surely used, so where in one Program the parameter decreases, in another one it increases, at least, this can be used that way. Furthermore the Percussion mode can be used which means each Slot can contain 8 synthesizers, so there is a possibility 32 different sounds are played; only the tonal range would be very limited but who is talking tonality here Smile. The keyboard is used as trigger.
I like to hint a way of obtaining these kind of sound tweaking projects on any synth: try a Midi randomizer and save all interesting results. Take notice of those parameters which will cut off the sound and adjust these if needed. Play the sound and explore what it can do sound wise.
At http://electro-music.com/forum/phpbb-files/random_and_improvisation_09_11_07_448.mp3
is a 2 Slot random improvisation done on the Nordlead3, which has a beautiful After Touch and 4 Morph groups.
Wout
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Oct 26, 2008 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I just made a single Program in the Nordlead2 using 'RandomPatch' in the 'Run' part of NordGen and adjusted some parameters like the Filter (no BP but LP24dB) and the FM to the ModWheel and recorded this.
I'm more in for the sustaining sounds rather then the 'blips&blobs', so...
For those with a NL2 the SysEx file is also there.
Furthermore some random Patches tweaked to tonal use able Programs, but only in SysEx.
Wout
Sound1.mp3
The sound
 Filesize:  495.02 KB
 Duration: 1:03
 Viewed:  1348 Time(s)
RndProj001A.syx
SysEx A-Tonal Program
 Filename:  RndProj001A.syx
 Filesize:  139 Bytes
 Downloaded:  394 Time(s)
RndProj001.syx
SysEx
 Filename:  RndProj001.syx
 Filesize:  139 Bytes
 Downloaded:  359 Time(s)
RndProj002.syx
SysEx
 Filename:  RndProj002.syx
 Filesize:  139 Bytes
 Downloaded:  392 Time(s)
edjwise
PostPosted: Sun Oct 26, 2008 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
So the morphing is the secret. . . No wonder I couldn't figure out what was going on.
msy2
PostPosted: Thu Dec 04, 2008 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm the one who made that video. i get a lot of questions about it and am trying to find the time to video tape a similar session from the start.
i use all four parts + arps + drums + lfo and then morph.
also keep in mind that as it plays i'm also changing patches in different slots sometimes. it is all improvisational so it is hard to remember what i was doing at them.
if you search my posts, i think i've got 4 wavs of this uploaded. the audio in the video is from one of the waves.
enjoy. i'll update this thread once i make a video of it.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Dec 04, 2008 8:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
msy2 wrote:
... enjoy. i'll update this thread once i make a video of it.
And maybe post a SysEx file one or two of the Programs used? We all want to learn Smile
Wout
