CGS07 Gate Sequencer RESET
Page 1 of 1 [4 Posts]
funkyfarm
PostPosted: Sat Dec 27, 2008 3:24 am    Post subject: CGS07 Gate Sequencer RESET Reply with quote  Mark this post and the followings unread
I have noob question : when I reset my CGS07, STEP 1 LED is ON.
Is it normal ?
This way, on a standard sequencer, your sequence's first note will not be played/heard as the clock is enable.
On start, all the LEDs should be OFF, no ?
Posted Image
otherunicorn
PostPosted: Fri Jan 02, 2009 11:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is meant to go to step 1 just like it is doing. There can be no "all steps inactive" state.
http://www.cgs.synth.net/
funkyfarm
PostPosted: Sat Jan 03, 2009 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
when I press START, the first STEP *briefly* lits before a normal pace come trough...
If T is period of clock signal, each led should be lit for T. After a Reset, STEP 1 is lit for about T/4 or T/8...
It's a SNAP, not a STEP Smile
sorry.
otherunicorn
PostPosted: Mon Jan 05, 2009 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
If the clock is running when you hit the reset button, that clock cycle will be divided between the current step, and the first step. That would explain why you get a shortened step.
