Coming up on Radio 1 at
How to record Midi-Notes from the Arpeggiator ?
Page 1 of 1 [3 Posts]
JG
PostPosted: Tue Dec 30, 2008 4:01 am    Post subject: How to record Midi-Notes from the Arpeggiator ? Reply with quote  Mark this post and the followings unread
I would like to record the Midi-Notes coming out of the NL2-Arpeggiator in Logic 8 but i don´t know how.
I don´t really understand the manual... Sad Could somebody tell me step by step how to do it ? thanks !
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Dec 30, 2008 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome JG
Manual Page 61 and 62 wrote:
Arpeggio and MIDI Out
If you want to, generated arpeggios can be sent out as MIDI notes. This makes it possible to arpeggiate chords on connected synthesizers and sound modules, and to record arpeggios in a sequencer. You activate it using the Prg. Ctrl. menu:
1. Press the Prg/Ctrl button to select parameter. The left character in the display switches between “P” (Program), “C” (Control) and “A” (Arpeggio).
2. Use the Program Up and Down buttons to switch between “of” and “on”.
*. For the Program and Control parameters, the “on” setting means that the respective MIDI data is trans-mitted and received by the Nord Lead 2, while the “of” setting means that it is not.
*. For the Arpeggio parameter, the “on” setting means that generated arpeggios can be sent out as MIDI notes. This makes it possible to arpeggiate chords on connected synthesizers and sound modules, and to record arpeggios in a sequencer.
With the “of” setting, the actual chord you play on the keyboard is sent to MIDI Out, regardless ofwhether the Nord Lead 2 arpeggio is activated or not.
Be sure to turn the Arpeggio MIDI Out feature off if you are using Nord Lead 2 in Local Off mode and/or in a “Thru-loop” with a sequencer, other MIDI instruments etc! Under such conditions, the ArpeggioMIDI Out feature will either prevent the instrument from sounding at all, or cause a MIDI feedback loop.
What don't you understand?
Wout
JG
PostPosted: Wed Dec 31, 2008 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey !
I finally got it Laughing
