Voltage Controlled Divider CGS09 -- weird module!
Page 1 of 2 [36 Posts]
Pulse Emitter
PostPosted: Sun Feb 08, 2009 6:46 pm    Post subject: Voltage Controlled Divider CGS09 -- weird module! Reply with quote  Mark this post and the followings unread
finally got this working, i think. main hang up was with the switched jack at the CV input. apparently the CVI point needs to be connected directly to CVN while a signal is coming through. the schematic shows CVI and CVN only connected when nothing is plugged in via the switched jack. nothing came through when wired that way. anyone else experience this?
so i think this module works. it doesn't seem to function like other dividers i've used. not sure yet how i'm going to make use of it, but only just got it working today, need to experiment more. i guess it puts out some odd pulse waveforms that could be good as LFOs or as a signal processor for VCOs. really don't know what i'll do with the staircase outs. also can't seem to figure out what the trim pots do.
any tips?
thanks,
Daryl
http://synthnoise.com
Pulse Emitter
PostPosted: Sun Feb 08, 2009 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh yeah, here's a link to the schematic for reference:
Posted Image
andrewF
PostPosted: Mon Feb 09, 2009 7:36 am    Post subject: Re: Voltage Controlled Divider CGS09 -- weird module! Reply with quote  Mark this post and the followings unread
From Ken's description of this module -" Use the control voltage input to determine the number of incoming pulses per output pulse. "
It doesn't sound right if you have the +15V and input CV signal connected together and I suspect it is probably not much fun for whatever module is supplying the CV signal. The 1k resistor will provide protection for a while.... Smile
the idea is, if you have nothing connected to the CV input, the division pot can be used to set the dividing ratio. Connect a CV signal and the dividing ratio is voltage controlled.
You might find it is not working as expected because you have not set the trimpots.
Ken describes the trimpots and how to set them up -
"The second part is used to set the minimum and maximum of the voltage presented to IC1A, as going past either end of the operating range results in either silence or an unpredictable oscillation. (Divide by 0 is NOT very practical!) "
"This module requires setting up. Feed an audio signal into the Clock In input. Monitor the output at HO Pulse Out. With the control voltage set at 0 volts, adjust the OFFSET trimmer until the input frequency equals the output frequency. With the control voltage set at the maximum (15 volts if wired as per the diagram), adjust the SPAN trimmer until you get the lowest frequency possible. If the output stops then back up until you get a signal again. "
As for using the VCDivider, there are no real rules, no right or wrong way to use it, feedback outputs to inputs, try it as an audio signal processor, experiment!
Pulse Emitter
PostPosted: Mon Feb 09, 2009 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
didn't think about it hurting the module connected but you're right! wired it back per schematic immediately.
tested the switched jack, it's good.
sorry, should have read the trim pot setup in the notes, forget that was there.
but man, now i'm still having the same problem. when a signal is plugged into the CV jack, no action, LED stays on solid--unless it's just barely resting in there making contact with with both points of the switched jack (the lug of the pot opposite ground, and CVN). unplugged nothing comes through either. the Division pot doesn't help, neither do the trims.
i'll have a look at the board and schematic and scratch my head a little bit... thanks for the help, look forward to experimenting with it once it's up and running!
more later,
D
Pulse Emitter
PostPosted: Mon Feb 09, 2009 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
yippee!! that was quick, i traced the CVN point on the board through the 1k to +15V, only to find a missing jumper! was not connecting to +15V. there are a lot of jumper wires to be soldered onto this board, and while i scanned it multiple times, just didn't catch that one.
just set up the trims per the notes. seems to be working, the staircase out looks much better on the O-scope. only now my LED isn't flashing Rolling Eyes anyway, making progress, thanks again... much experimenting ahead with this most interesting module.
Daryl
whomper
PostPosted: Mon Feb 09, 2009 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just got back to my module and found out that my module is too acting weird.... Sad
I get no audio on the "MO" output so could not follow Ken's settings suggestion. I get no output out of the 4024. The led changes flashing speed as I turn the division pot and I get proper division at the LO out, but the 4024 does nothing.
Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de
zthee
PostPosted: Wed Feb 11, 2009 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
But the MO output is just the mixer output of the incomming clock signal?
The comp sense pot sets how sensitivite the pre-comparator will be? Which means that if you've set it to high it will not send a clock pulse to the comparator, and that in turn will not drive the 4024?
So either IC3 isn't working, or IC1 is faulty?
Trace the incomming clock pulse? Does it pass the pre-comparator? If so, does it pass the comparator? If so, change the 4024? Smile
I've got a CGS09 in my backlog. Hope to get alu for my panel soon, so I can get it all together!
otherunicorn
PostPosted: Mon Feb 23, 2009 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
MO is just a mix of the Clock and other related voltages. It is there so you can use the input stage as an ordinary CV mixer if you are not using the module for dividing.
http://www.cgs.synth.net/
Funky40
G2 patch files: 5
PostPosted: Thu Feb 26, 2009 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I need something like the VC-clock part from the new Motm 730
click on top left corner: http://www.synthtech.com/new_stuff.html (btw. it has very nice Demos on the Motm730 page )
Would the CGS09 do ?
andrewF
PostPosted: Thu Feb 26, 2009 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
maybe the VC Divider combined with a CGS36 Pulse Divider would do the job. Not exactly the same as the MOTM but getting close and about $350 cheaper if you DIY.
Funky40
G2 patch files: 5
PostPosted: Fri Feb 27, 2009 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks Andrew !
I will try, the 350$ are an argument Wink and shipping from Ken is so cheap, so no brakes there.
only drawback is the big backlog. Must go thru the haible stuff........
i see REALLY lots of potential to get nice grooves with some CV clockdivison lines.
the full random thing is not really my world as it seems
Funky40
G2 patch files: 5
PostPosted: Sun Mar 15, 2009 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I found a CGS09 board while cleaning.
It's popultaed and the module ready for wiring.
something is not clear concerning CVN and CV In.
On the schematic is a 1K resistor on the CVN connectioon which is an output ( to be normalised to the CV in jack as i understand )
On the Board i have 10K. seems that it was also as 10K labeled.
I assume here's an error or am i wrong Question
finally i will wire the CV Manual control separatly and making two CV inputs, each with attenuation.
seemed worth to layout the module this way.
so when wiring directly to a pot i even could omit the Resistor if it's really a 1K, not Question
zthee
PostPosted: Sun Mar 15, 2009 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just got mine working. Haven't listened to it. But it seems to function OK.
The staircase down seems to have a bit of offset - it starts like -2V or -3V and then goes downwards. I'll check it tomorrow. Maybe need to change the 100K around IC4b to something different...
andrewF
PostPosted: Sun Mar 15, 2009 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Usually it is safest to follow the schematic, but in this case it won't make much difference if you use 10k or 1k. The resistor is there to protect the output of whatever you are plugging in from getting directly connected to the positive rail in the brief time before the jack switch opens.
If you are going to have a dedicated CV manual control, there is no need to use the CVN connection at all, or omit the 1k(or 10k) resistor and wire +V directly to the pot. Of course, connect the pots wiper to 10k like the other CV pots going to CVI.
Funky40
G2 patch files: 5
PostPosted: Mon Mar 16, 2009 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, its clear then,
thanks Andrew !
Funky40
G2 patch files: 5
PostPosted: Tue Mar 17, 2009 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I have my module wired up, but have a little issue with trimming:
I cannot get the outputfrequecy following the inputfrequency. ( HO out )
I have a divison by 1:7 as the smallest i can get.
Any tips from down under ?
Funky40
G2 patch files: 5
PostPosted: Tue Mar 24, 2009 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
nobody ?
andrewF
PostPosted: Tue Mar 24, 2009 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
First thing, check you have 0V at CV IN. If you don't, this probably explains why it won't match frequencies.
If you do:
The 10k resistor and 2k offset trimmer combine to give an offset voltage ranging from 0 to -2.5V.
Try increasing this range, for now just spot-solder a 4k7 resistor over the 10k, so they are in parallel. this will give a range of 0 to -4.5V.
Now try and do the setup routine again.
if it works, measure the offset voltage and replace the 10k with something that will give the appropriate voltage (most likely the 4k7 will do)
Hopefully this will allow you to match the input and output freqs.
It is a bodge tho, doesn't really answer the question of why you cannot set it up with the specified components.
have fun Smile
Funky40
G2 patch files: 5
PostPosted: Wed Mar 25, 2009 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Andrew, i've putted the 4K7 in paralell, and turned the trimmer somewhat back,
but i had to turn it again back. when it reached the end i got 1:1 clock.
So 4K7 is very much on the edge.
I don't understand the maths ( serenadi tryed explaine me allready ), so giving it a little more "headroom" then with the 4K7 waht would be right to replace the 10K or maybe just the 4K7 ( don't like to desolder on the borrds )
Thanks Andrew !
I didn't checked this. ok, i did ( had first no idea where, but damned, im'm nomore that noob i was Wink )
I have 0 volts on the -Input of the TL072, but i have 4.7 Volts on the Output of this IC.
Nothing pluged into this module, all the pots full CCW.
sounds funny to me. Just checked with another TL 072, still the same.
ok, so there must be a fault in the near, but nothing visible to me
Funky40
G2 patch files: 5
PostPosted: Wed Mar 25, 2009 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
WOW, the module is fun !
i can make 2voices with one VCO, patched over two LPGs it's allready really cool.
Can't record anymore in the net-PC ( EMU soundcard, good audioquality but driver sucks )
hehe, need two more VC Dividers Laughing
andrewF
PostPosted: Wed Mar 25, 2009 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have a check the diodes around IC2B are installed corrctly.
If all okay...well
just replace the 10k/4k7 combination with a 2k (or 2k2). This will give you a range of 0 to -7V or so, which will be plenty.
Then do the setup procedure again to get 1:1 input/output ratio.
Keep in mind, this is a bodge, that is effectively masking a problem elsewhere but not solving it. Hopefully it will all work as normal and you never have to think about it again or at least until you build another.
but be aware it may eventually cause other problems.
good thing we are not building medical equipment or passenger jets Razz
oh - a google for 'voltage divider' will turn heaps of introductory articles on calculating this.
Funky40
G2 patch files: 5
PostPosted: Thu Mar 26, 2009 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep ! thanks for your help
hehe, yes.
but did you know about the problems they had (or have) with replacement Parts ?
clones and optical repaired old stuff everywhere.
I saw a documentation years ago Shocked Shocked Shocked
clones are not allways welcome Laughing
Luka
PostPosted: Wed Aug 05, 2009 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
hey does anyone have any panel designs for this
i need a reference to work from
problemchild
melbourne australia
zthee
PostPosted: Wed Aug 05, 2009 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
It's missing the stair down output though. And the CV in could probably use an attenuation pot.
 Filesize:  31.86 KB
 Viewed:  26104 Time(s)
Luka
PostPosted: Wed Aug 05, 2009 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
what uses come from the stair ouputs?
i just thought this was a divider
btw is it hard to set accurate divisions?
is it 1v/div or something?
problemchild
melbourne australia
