Electro 2: different levels of organ and piano sections
Page 1 of 1 [2 Posts]
funkster
PostPosted: Thu Apr 16, 2009 10:45 am    Post subject: Electro 2: different levels of organ and piano sections Reply with quote  Mark this post and the followings unread
I didn't know where else to ask this question:
The organ section of my Electro 2 outputs a very much lower level than the piano side (which is fine). So low that it is almost unusable. I am sure it used to be much louder (I haven't been using the keyboard a lot recently). This is with all the drawbars at max.
The only thing I can think of is that I uploaded some different Nord piano library samples some time ago, but nothing unusual.
Does anyone one kindly have any tips or ideas?
thanks
The Strout
PostPosted: Wed Apr 22, 2009 2:33 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Have you tried to overwrite the programmed volume on your organ sound by changing the output level (top right knob) and save... ???
you can save the output volume on any sound... not only on piano
If that doesn't work then I would reset the memory and load it up again...
Good Luck Smile
