Coming up on Radio 1 at
CC modulation of drums on Nord Rack 1?
Page 1 of 1 [2 Posts]
Filament
PostPosted: Tue May 12, 2009 12:40 pm    Post subject: CC modulation of drums on Nord Rack 1? Reply with quote  Mark this post and the followings unread
I just recently bought a Nord Rack 1, 2.3 E rA
I found the drums on P0 - P9 and I know you can edit the sound of each of the 8 drums by pressing the black key for each range, but I cannot find a way to modulate the drums using midi cc's.
Can anyone please help me?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue May 12, 2009 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two ways of changing the sounds of running Percussion mode.
1 Create a Morph to all the sounds you need to change (I can imagine a hi-hat doesn't need to change much) and use the ModWheel to perform the changing, but all the eight sounds (when all are Morphed) will change at the same moment.
2 For each sound seperated program in the sequencer (computer) a 'black' control MidiNote, which sets the zone into Edit mode and change the parameter using a CC. Note when a 'control' MidiNote is used that particular zone stays active in Edit mode until a new control MidiNote is send to another zone.
3 Another way is Using 4 Percussion sound in 4 Slots spread over the whole Keyboard, just like a normal Program or Performance. Using 4 Midi channels the 4 Programs can be changed at any time in any parameter needed. The Lead is reduced to a rather limited drum machine, but it works...
Wout
