Macaba's Musings
Page 1 of 1 [5 Posts]
Macaba
PostPosted: Wed May 27, 2009 9:41 am    Post subject: Macaba's Musings Reply with quote  Mark this post and the followings unread
After chatting to Les, in particular, in the chat room, I've decided to follow a path and see where it leads me.
It involves using this rather nice IC: ADAU1761
I ordered some samples and a breakout board for the particularly fiddy package. (LFCSP32)
Posted Image
Posted Image
I shall solder it in the next few days and power it up!
The IC is a codec (ADC + DAC) that has a built in DSP Core. It may well be the DSP core does not suit our purpose, but there is another IC, ADAU1361, that is the same but without the DSP core, so we could conceivably use an external DSP processor that is more open to hobbyists, like dsPICs.
Inventor
Audio files: 270
PostPosted: Wed May 27, 2009 8:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Macaba (Mark), thank you so much for jumping in on the eChucK project! You have a lot of great ideas that we can mull about to see what works for the project.
I also like your idea of securing the boards into a sculpture with non-electrical solid wire and then using stranded wire for the electrical signals. That way a sculpture can be rewired as desired without falling apart.
It's good as well that you're on board (pun intended) with the Lunetta board and including your processor on it, plus you have access to a shear and plan to do hotplate SMT fab, all great resources for the project. Plus other stuff I don't recall at the moment.
Let's use this thread as a way to record your thoughts so they don't get lost in a puff of smoke like so many great ideas. Best to ya!
Les
Macaba
PostPosted: Fri May 29, 2009 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I soldered the IC onto the protoboard:
Posted Image
Closeup of solder joints:
Posted Image
Macaba
PostPosted: Wed Jun 03, 2009 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
slow but steady progress....
Posted Image
here I've soldered the decoupling caps and the ground wires.
Unfortunately I've just moved house and left my nice flexible hookup wire somewhere else, so it'll be a few days before I can wire this upto a micro and make some sine waves!
Inventor
Audio files: 270
PostPosted: Wed Jun 03, 2009 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice progress, Mark, more than I can say for myself at the moment. I'm busy unpacking from the move. Then comes guitar surgery and finally I get back to eChucK. Will be working on the lunetta board for sure.
Les
