Findings about the Nordlead
Page 1 of 1 [3 Posts]
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 03, 2009 2:36 pm    Post subject: Findings about the Nordlead
Subject description: Some results from investigations...
How many Voices has the NordLead2?
Sometimes it looks if there are less then 16 Voices available without the use of the Unison (which provides the half = Voices).
To keep the keys triggered I used paper tape as soon the sound is there.
Staring with the highest note in a particular octave setting and keeping this note pressed, I pressed and taped the lower octaves. The 17th keypress mutes the highest note (which can be clearly heard) and replacing it with the sound of key press 17, e.g. a two octave lower one.
Conclusion: there are 16 Voices available without Unisn.
Listen to the mp3 file.
Enjoy the looks of my heavily abused Lead...
Wout
16_Voices.mp3
 Filesize:  318.49 KB
 Duration: 0:41
 Viewed:  1667 Time(s)
 Filesize:  123.59 KB
 Viewed:  5664 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 03, 2009 2:43 pm    Post subject: Detuned on headphones? Reply with quote  Mark this post and the followings unread
During above tests I noticed some tones were out of tune. The next mp3 file has a little detuned sound at the 6th sound of this Arpeggiator configuration. Playing a C maj chord together with the mp3 file changed it back to normal.
Only on headphones.
Something psychologic?
Wout
6th_note_detuned.mp3
 Filesize:  68.9 KB
 Duration: 0:09
 Viewed:  1707 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jun 03, 2009 2:50 pm    Post subject: Arpeggiator hick-ups Reply with quote  Mark this post and the followings unread
At http://electro-music.com/forum/topic-34664.html&sid=768a0641bafe23e20e06657388bc7737
there was mentioning about irregular hick-ups.
The only way to archieve something like that is using Percussion mode and mute some regions.
Note the highest sounds have Glide and Unison for FX (by the NL2!)
Wout
Arp_HickUps_PercussionMode.mp3
 Filesize:  521.96 KB
 Duration: 1:07
 Viewed:  1686 Time(s)
