melmac
Joined: Aug 19, 2009 Posts: 27 Location: Schleswig-Holstein (Germany)
Posted: Wed Aug 19, 2009 10:36 pm Post subject:
Nord Rack 2X doesn't receive Pitchbend/Modulation/Aftertouch Subject description: And: Is a Reset of the device possible? |
Hi together,
I'm new - and I have a problem with my Nord Rack 2X that I have bought just now (second hand!).
The device behaves "normal" and receives the MIDI-data from my Master-Keyboard (a Korg Triton 61 LE) e.g. when pressing a key. But when I use the Pitchbend- or the Modulationwheel on the Master-Keyboard (= the Joystick) there is no effect on the 2X (and also the trigger-LED on the 2X doesn't glow in this moment). The Korg definitely sends Pitchbend- and Modulation-Data (checked with the PC). I think the 2X doesn't receive or doesn't "understand" the controller data.
Also I did not hear any effect when "using" Aftertouch.
I have tried all the different settings on the 2X - but no success!
Could give me someone helpful information about this problem or is there perhaps a "damage" (I don't hope so)?
Another question: Is it possible to do a complete "Reset" of the Nord Rack 2X to re-produce the original state of factory/delivery again?
Thank you very much in advance! |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Aug 20, 2009 4:51 pm Post subject:
Re: Nord Rack 2X doesn't receive Pitchbend/Modulation/Aftertouch Subject description: And: Is a Reset of the device possible? |
melmac | melmac wrote: | I'm new - and I have a problem with my Nord Rack 2X that I have bought just now (second hand!).
The device behaves "normal" and receives the MIDI-data from my Master-Keyboard (a Korg Triton 61 LE) e.g. when pressing a key. But when I use the Pitchbend- or the Modulationwheel on the Master-Keyboard (= the Joystick) there is no effect on the 2X (and also the trigger-LED on the 2X doesn't glow in this moment). | That last remark indicates both modulators aren’t send to the NR2X at all! | Then melmac wrote: | | The Korg definitely sends Pitchbend- and Modulation-Data (checked with the PC). | Than it should receive Midi and the LED indicates it doesn’t… | Not me, but melmac wrote: | I think the 2X doesn't receive or doesn't "understand" the controller data.
Also I did not hear any effect when "using" Aftertouch. | Did you assign AfterTouch? See [Manual page 74-75] | melmac also wrote: | | I have tried all the different settings on the 2X - but no success! | Which settings do you mean? | melmac clearly wrote: | | Could give me someone helpful information about this problem or is there perhaps a "damage" (I don't hope so)? | I can’t tell yet… | melmac hopefully wrote: | | Another question: Is it possible to do a complete "Reset" of the Nord Rack 2X to re-produce the original state of factory/delivery again? | No there isn’t…
Wout
PS Sorry for the quoting fun, but I need it reading all those trouble loaded posts lately…
 Last edited by Wout Blommers on Fri Aug 21, 2009 2:12 pm; edited 1 time in total |
melmac
Posted: Fri Aug 21, 2009 12:39 pm Post subject:
Re: NordRack2X doesn't receive Pitchbend/Modulation/Aftert. Subject description: And: Is a Reset of the device possible? |
Wout, thank you very much for your efforts!
Now after a little more time with my second clavia device I managed to get all the "missed functions".
The reason for "no Pitchbend/Modulation/Aftertouch" were the MIDI settings of my Korg Triton (in combination with the - for "Lead-beginners" - very unusual MIDI-behaviour and slot-organisation).
Furthermore I have been irritated because of the trigger-LED only went on when pressing a key and not e.g. when turning the mod-wheel (my Electro 2 73 shows every MIDI-IN command by LED even for contoller actions of a master keyboard).
So finally my small red one produces the sounds I like and I am looking forward to exploring the possibilities...
It is a pity that there is no "Reset function", that would be very helpful.
Thank you all for a very interesting and useful forum. I will stay tuned. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Fri Aug 21, 2009 2:16 pm Post subject:
Well, maybe we'll read again as soon as you try "Midi of leftmost active Slot" and Performance Program Change...
Wout |
