Nord Rack 2x: Newb! 2 questions...
Page 1 of 1 [10 Posts]
siderealxxx
PostPosted: Tue Oct 20, 2009 7:40 am    Post subject: Nord Rack 2x: Newb! 2 questions... Reply with quote  Mark this post and the followings unread
So hello Nord community Smile I am now the proud owner of a Nord Rack 2x and so far I like what I hear. Very flexible, yet basic without sounding like it. My cup of tea.
Anyway, I have 1 or 2 newb questions so I apologise, but it'd be helpful (oh and I am referencing the manual but so far I'm still stuck on these points):
Firstly, a question about outputs... I have the A/B outputs plugged into my mixer and C/D directly into my interface (for recording audio without having to go through the mixer). I would simply like to assign a duplication of A/B to C/D so when my MIDI is done, I can record to audio. However I've tried all of the settings in 'Out Mode' and can't actually get any sound out of C/D?!?! Is it in some way related to the slots or MIDI channels? How do I set this up?
Secondly, a question about factory reset/initialize. This unit was 2nd hand and I have no idea what sounds are factory and which are the previous owner (I know they will only be in the first 4 RAM banks), but I can't see an option to initialize the unit so it is as it left the factory. How is this possible?
Thanks for your time - any help greatly appreciated!
Cheers, Sidx
siderealxxx
PostPosted: Tue Oct 20, 2009 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh and one more thing... the software version is still V.1.0 I believe. On the Clavia site there is no mention of any updates to this - is that right?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Oct 20, 2009 2:59 pm    Post subject: Re: Nord Rack 2x: Newb! 2 questions... Reply with quote  Mark this post and the followings unread
welcome siderealxxx
siderealxxx wrote:
So hello Nord community Smile I am now the proud owner of a Nord Rack 2x and so far I like what I hear. Very flexible, yet basic without sounding like it. My cup of tea. Anyway, I have 1 or 2 newb questions so I apologize, but it'd be helpful (oh and I am referencing the manual but so far I'm still stuck on these points): Firstly, a question about outputs... I have the A/B outputs plugged into my mixer and C/D directly into my interface (for recording audio without having to go through the mixer). I would simply like to assign a duplication of A/B to C/D so when my MIDI is done, I can record to audio. However I've tried all of the settings in 'Out Mode' and can't actually get any sound out of C/D?!?! Is it in some way related to the slots or MIDI channels? How do I set this up?
This is a tricky one… First of all why has the NordLead2(X) this strange set up? The original NordLead has only two Outs, A and B. C and D were added, but the design didn’t changed that much, so C and D can be directed to A and B, but not the other way around! The only option is to use only sounds which uses only two Programs and load both into Slot A and C, Slot B and D respectively. By setting A and B, C and D to the same Midi channel respectively, it should work. Troublesome are factory Performances.
At http://nm-archives.electro-music.com/020_NordLead2/021_Patches/ you’ll find the Program Archive. Take a look at 3100 to 3400 and us a tool like http://nm-archives.electro-music.com/020_NordLead2/023_Miscellaneous/NordGenerator_Editor/ to get the Programs from the computer into synthesizer.
AFAIK that’s right.
Wout
siderealxxx
PostPosted: Wed Oct 21, 2009 3:15 am    Post subject: Re: Nord Rack 2x: Newb! 2 questions... Reply with quote  Mark this post and the followings unread
Thanks for the reply/help!
I think I need to understand this a little clearer. Firstly, what is the best output mode to use for general purpose? I am only likely to use 1 sound at a time at this stage and my system is geared up to record in stereo. So should I use Out Mode 1 or 3? The manual says that for Out Mode 3 all programs always appear with voices alternating between Outputs A & B? That sounds strange (maybe I don't undeerstand). Or should I just stick to Out Mode 1 and record in stereo anyway?
What I don't understand is that a mono sound appears out of both outputs doesn't it (A&B for example)? Yet, what if you place a sound on each of the 4 slots? Do they only sound out of 1 output? I'm confused! Am I overcomplicating myself here and should I be thinking in mono?!
Anyway, how do I now get my MIDI sequence over to the outputs C & D now to record to my computer (and include any knob data etc)? I select the same MIDI channel (1) on C & D and just reselect that sound? But on which bank if it's mono C or D or both? Mono/stereo? I still don't get it!
Secondly... thanks for the links. However when I click on the /020_NordLead2/021_Patches/3100_NL2X_FactoryPresets_00 for example each of the syx files are only 1kb and only load some weird text. If I download them they are 4kb. Is this right? And do I have to do each one individually?
Also I don't have a PC so can't use Nord Gen Editor. I do have SysEx library will this help?
Agh! I'm getting new equipment headache! And I'm determined to understand this so I can get the most out of it and have it working how I want it.
Any more info would be helpful! Thanks!!!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 21, 2009 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
General purpose is [1.Ab] and [-.cd] All goes through Output A and B, even what’s been loaded into Slot C and D, so when using Performances.
Everything you do is in mono unless you pushed the Unison button, than it is stereo with detuning, but setting the Unison to [Un1] by pressing [Shift + 3x System (=Auto)] it is ‘mock-up’ plain stereo. In your set up using only one Program in Slot A set the Output mode [Shift + Out Mode (= SlotB)] > [1.Ab] and this will sound the described stereo in Out A and B through your mixer to hear it. Also upload the same Program into Slot C and set Output Mode C and D by [Shift + 2x Out Mode] > [1.cd]. Output C and D will enter your computer to be recorded into your program. Both Slot A and C have to active to be heard… BTW did you know you can split input lines? I should do this using a PatchBoard… Not that expansive, BTW see http://www.behringer.com/EN/Products/PX1000.aspx or something...
Stick to [1.Ab]. Mode 3 is a trick to play with the stereo spreading for long and sustaining sounds like strings without using the Unison mode (This last one reduces the number of voices…)
Not if you choose [4.Ab]
That’s right. You have to use the Panning on the desk.
Whatever you like! I don’t want to control your thoughts Wink I should make it myself easier using a Patch Bay! Output A and B into two channels and it comes out in 2 times these signals…
All Programs in the memory are available to all Slots, so they can be loaded in all Slots. All Programs are in essence mono, only Unison delivers it in a mock-up stereo (little delay on one of the two, besides detuning). So, in a way, the Lead is thinking mono already. Why shouldn’t you? Wink
Strange… I downloaded them too and they are only 139 bytes… Shocked
Yes, of course! You can’t compare complete Banks!
I don’t know, cause I never tried this. If it works or not, tell it here!
Take an asprine, take a cigar, take a shot of gin or take your wife, whatever works for you!
Well, I mostly buy my asprins at the drugstore. The rest you have to find out yourself…
Thanks!!!
You’re welcome, but I wrote that in the beginning of my previous post, didn’t I?
Wout
(just a little bit funny during boring work… Cleaning out the house…)
siderealxxx
PostPosted: Wed Oct 21, 2009 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
ok - great I think I get it now Very Happy :::Clap::: My computer has gone to have some work done on it so I can't try anything until tomorrow now.
Thanks for the response again... you sure seem to know what you're talking about.
Is there anywhere else I can get those sysex files?
I think there could be more questions to come over the next few weeks as I get my head round this. I've not used much MIDI for years... It's all been softsynths, but basically I hate them!
Thanks again
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 21, 2009 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I heard about that... Mac's are very hard to keep indoors...
Well, I know how to create that impression. Clavia is monitoring this Forum for sure and I think it will cause many laughs in Stockholm Smile
I don't think so. I search for many years and this is all I found, at least for free.
That's okay. I have learned a lot answering questions like this. You are the first one who wants to create a special set up connecting the synth parallel with the computer input. I assume it's all because you want to correct the quality later on or is it to mimic a softsynth configuration. Beware, the NordLead doesn't do any rendering or bounces.
Well, everybody is always hiding something from the past.
Wout
siderealxxx
PostPosted: Wed Oct 21, 2009 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
The manual clearly states that if you overwrite a patch and wish to return it to the factory setting that midi files will be available from the Clavia website. As far as I can see they're not there! I'm suprised that these aren't available more easily? Is it worth mailing tech support? I'd really like to 'initialize' the unit so to speak.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 21, 2009 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't find the posting anymore, so I'll have to create a double in the attachment files.
I have the four files in Midi.
(And one extra)
Wout
lead2x_bulk_dump_bank_0_188.mid
 Filename:  lead2x_bulk_dump_bank_0_188.mid
 Filesize:  24.3 KB
 Downloaded:  290 Time(s)
lead2x_bulk_dump_bank_1_552.mid
 Filename:  lead2x_bulk_dump_bank_1_552.mid
 Filesize:  24.3 KB
 Downloaded:  289 Time(s)
lead2x_bulk_dump_bank_2_732.mid
 Filename:  lead2x_bulk_dump_bank_2_732.mid
 Filesize:  24.3 KB
 Downloaded:  299 Time(s)
lead2x_bulk_dump_bank_3_172.mid
 Filename:  lead2x_bulk_dump_bank_3_172.mid
 Filesize:  24.3 KB
 Downloaded:  304 Time(s)
internal.mid
 Filename:  internal.mid
 Filesize:  5.6 KB
 Downloaded:  324 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Oct 21, 2009 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I hope you have use for *.mid files...
This is the only place (electro-music.com) where to find these.
Spread the word... Smile
Wout
