RJcfc
Posted: Sat Dec 26, 2009 1:09 pm Post subject:
Nord Rack 2X Problem - Help Please |
I just bought a Nord Lead 2x rackmount a few weeks ago and all was fine until yesterday.
When I select a sound, for example sound 1. 5, when I start to manipulate the sound, the Nord automatically switches back to sound 1. 1.
It doesn't matter which sound I choose, each time I manipulate it, it always changes back to the very first sound of that particular section.
Has anyone else experienced this? |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sat Dec 26, 2009 3:21 pm Post subject:
RJcfc
Unplug the Midi Cables and try again.
Maybe it's a Midi loop.
Wout |
RJcfc
Posted: Sun Dec 27, 2009 6:50 am Post subject:
| That seems to have solved the problem, thanks very much. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Sun Dec 27, 2009 7:06 am Post subject:
No, no, no...
You won't get away that easy!
What could have caused the MidiLoop?
Connect the Midi cables again, press [Shift+2x MidiCh] and you are in Global Midi mode. Set the Global Midi to channel 16.
I wonder if the troubles still happen...
Wout |
RJcfc
Posted: Tue Dec 29, 2009 9:25 am Post subject:
| Wout Blommers wrote: | No, no, no...
Wout |
I done that and the problem is gone. Everything seems ok now.
EDIT: It happened again. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Dec 30, 2009 1:22 am Post subject:
| RJcfc wrote: | | ... EDIT: It happened again. | I told you it wouldn't be an easy one to solve, specially because I can't see the Midi set up. I think it's a Midi problem, which is mostly the case with a Rack...
The Rack can be controlled by a Midi controller or a Midi sequencer, mostly a software version on the computer like CuBase. A Midi controller mostly doesn’t receive Midi but only sends it.
The software sequencer receives Midi, of course, and has to send it back (echo) to the synth module. The first option would be to press [Shift+Local] and scroll using the up&down arrows to [off]. To change the knobs the computer has to be running the software…
It could solve the problem, but I’m afraid it doesn’t…
The next option is to change the Midi Trough or send Midi settings in the software. The could be a Midi Filter too, like CuBase which forces you to think ‘negative’ which means enable the Midi Through means it isn’t coming out anymore… (This is a feature created to drive musicians crazy )
Because I can’t see your set up from here you have to try these things yourself. If any success please let us know.
There is an translation of the knob data to ProgramChange data somewhere on the line…
To chear you up…
When all fails, sell the synth and buy real instrument like http://www.youtube.com/watch?v=SFgqDSBba1g
Ship and sun cap are included…
Wout |
