Anyware Tinysizer
Page 1 of 1 [2 Posts]
monokit
G2 patch files: 8
PostPosted: Tue Jun 22, 2010 11:26 am    Post subject: Anyware Tinysizer Reply with quote  Mark this post and the followings unread
Hi all, long time since last post. Sold my G2 (and most other stuff). Got myself the Tinysizer, one of the smallest modulars I know.
Posted Image
It has 2 VCOs, 3 LFOs (slow, fast, audio), 2 EGs (normal, fast), 4 VCAs, a great SEM based filter (LP, BP, HP), and audio input stage (preamp, env follower and gate trigger), a digital FX unit (delay, reverb, mixable), wave processor, mixer, ring, S&H, noise (white, pink), built in MIDI->CV, 10 external in/outs, and a ton (300+) of patch points. Check out the block diagram here: http://www.anyware-instruments.de/images/tinyinfo/images/tinysizer_block_big.gif.
Patching this synth is totally different from patching my MOTM with its big fat quarter inch cables. On the Tiny everything is under your eyes, no arm stretching. It a bit like patching a VCS3 matrix with tiny cables. No normalled routes, you have to wire the whole thing yourself. It's lots of fun. On the MOTM everything is more physical.
Here's a sexy pic I made:
Posted Image
Here's a demonstration of the SEM based filter, where the inputs are slowly overdriven:
http://soundcloud.com/klontart/tiny-filter1
This is the Tiny used as a filterbox. A cheesy drum sequence is fed into the audio preamp where it is boosted massively, and then into the filter, which is modulated by an EG triggered from the env follower:
http://soundcloud.com/klontart/tiny-filterbox1
And finally a demo of the filter at breaking point, modulated by two slow LFOs (tri and square):
http://soundcloud.com/klontart/tiny-filter-gurgle1
I really like the filter, which can be sweet, but I like it most for its raw power. A single VCO source will start to overdrive the input around 7 or so on the pot. The lowpass sound is nice and fat, and the bottom end stays when turning up the reso.
Hope you like the demos.
Robert
klontart sound and vision blog: http://www.klontart.com
Taylor
PostPosted: Sat Oct 02, 2010 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, this is a cool unit. I prefer to build all of my own stuff, but I must give this company kudos for a very well-thought-out device. The form factor and everything about it is unique and cool. It's not easy to come up with something that works as well as the usual standards, but I can see myself using this kind of thing. Might need to break down and finally get glasses to see those little header patch points, though... Rolling Eyes Wink
