Dead keys on a nl2
Page 1 of 1 [11 Posts]
expermusic
PostPosted: Mon Dec 06, 2010 9:41 am    Post subject: Dead keys on a nl2 Reply with quote  Mark this post and the followings unread
Sad
So, before I freak out about getting a bum deal, does anyone have any suggestions for why I have notes on about the lowest 2 octaves, but nothing on the higher 2 except about 3 keys? Could this be a loose connector or something?
Macbook 2.4 Unibody/Nord G2 Engine/9u of Euro Modules/Elektron Machinedrum SPS-1UW/NI Maschine/Novation Remote Zero SL MKII/
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Dec 06, 2010 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Are those three keys at the bottum of these two high octaves?
If so, you are using a KeyboardSplitt from D# and no sound in Slot C nor D.
Wout
expermusic
PostPosted: Mon Dec 06, 2010 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, it is definitely keys in the middle of the octave, and there is no keysplit on. It also occurs throughout any preset or performance. I've loaded each slot with the same preset, each one plays fine, full polyphony and everything, but every patch has the same dead keys. I should also mention that it works fine over midi. This is definitely a physical problem with the keybed I suppose...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Dec 06, 2010 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
So you want to open up the synth?
Take a look at http://nm-archives.electro-music.com/020_NordLead2/Red_Lady/Index_bestanden/Red_Lady/Weighted_part_2.htm.
On the first image you see the two flat cables (gray and blue) which you have to check. Open the connector and connect these again.
For opening the synth see a little lower in the article.
Maybe there is a loose connector in the keyboard itself. I never had to repair this. The keyboard is still availlable from Fatar.
Wout
expermusic
PostPosted: Mon Dec 06, 2010 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for you help, but that link seems to be dead. I get a 404 message.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Dec 07, 2010 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, there was a dot at the end which corrupted the link, sorry.
Wout
expermusic
PostPosted: Tue Dec 07, 2010 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your help! I opened it up and indeed one of the ribbon cables was not fully seated. All is well now.
But man! There is a ton of wasted soace in there!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Dec 07, 2010 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
expermusic wrote:
... But man! There is a ton of wasted space in there!
Sssssh!!!
That´s where I hide the dirty books...
Or my saving money...
Whatever...
Ever opened up a Nintendo? You´ll be surprized.
It's our hands which determines the measurements of the interface and therefore the complete synth Very Happy
Wout
expermusic
PostPosted: Tue Dec 07, 2010 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm thinking I could cut out a hole and slide either my mopho or machinedrum in there!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Dec 07, 2010 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
When cutting and drilling in the hood be sure you remove the panel board first: it could be damaged...
I have a Nord Modular Classic Rack mounted there, but it is on top.
Maybe it's better to use the top only without the cutting Smile
And holes aren't nice when selling the synth.
Wout
expermusic
PostPosted: Tue Dec 07, 2010 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess I was only half serious... Wink
The thing is, I've always kept my keyboards on a rolling ikea cart that I push under my desk when not used, to minimize space. I don't think I have the clearance to have something else on top of the Nord. I may even need to get a different, wider cart for this anyway, since all the weight of the NL2 is to the left, I feels just slightly tipsy unless I move it off center to the right more...
