add new banks on my nord lead 2 with dsp discovery
Page 1 of 1 [6 Posts]
analogica
PostPosted: Wed Feb 16, 2011 4:37 am    Post subject: add new banks on my nord lead 2 with dsp discovery Reply with quote  Mark this post and the followings unread
hiiiii
Can I do that???, can I send SYX archives or add new banks to my nord lead internal memory???
thanks
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Feb 16, 2011 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Only when you are using DiscoDSP Discovery Pro R4, in which you are able to export the SysEx.
It only uses the parameters available in the NordLead.
It doesn't work that compatible as one would like.
Wout
analogica
PostPosted: Wed Feb 16, 2011 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey,
I have dsp discovery V 5.4....
I open edit---file-----export----clavia nord patch....but thats all...
I dunno how to send the sounds to the banks on the synth, if i make the vst sound doing....
nuendo track IN--midi port
nuendo track OUT---discovery
I supposed it should the other way around....but the program doesnt let me put discovery in the IN....
Is that right??? i need your help, thanks
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Feb 16, 2011 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
analogica wrote:
... I have dsp discovery V 5.4....
Then a window has to open where you want to export the SysEx file to on your hard disk.
From that location you can send the file into the buffer memory of the NordLead.
NordGen can be used to do this.
Wout
analogica
PostPosted: Fri Feb 18, 2011 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
im sqeezing my head!!!
i cant dop that...I try with midi in to export and midi out to export....but im lost on that window
i do: FILE --- EXPORT ---- CLAVIA NORD LEAD 2 PATCH ----and then
which one is the folder???
if i want to import from clavia banks i dunno which folder is that one, ive checked evrything
-maybe i miss something, im not sure if i need a card on the nord lead,
i have 16 sounds to change on the internal memory, dont I???
thanks again man, i hope you can help me
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Feb 18, 2011 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I send a JPG from my computer screen, OS is Windows XP
In the left is Chainer, a VST host, loaded with discoDSP Discovery
In front of it Discovery itself, right clicked on the surface opens File > Export > Export Clavia Nord Lead 2 patch. Left click opens window: Discovery - Export -> Program(*.syx)
I name the file and save.
Then I open NordGen and load the file from the hard disk.
Press Send in NordGen and if the Midi is right the Program is in the NordLead.
Wout
A large picture...
 Filesize:  840.66 KB
 Viewed:  401 Time(s)
