Mini Wave: Table Tilting
Page 1 of 1 [7 Posts]
Vo1t
PostPosted: Fri Feb 25, 2011 1:00 pm    Post subject: Mini Wave: Table Tilting
Subject description: Tilting the tables on a Mini Wave
As you know the Miniwave can be externally driven with a ramp wave, the ramp is used as a index for the wavetable.
What if you morphed the ramp wave from a linear wave…
Posted Image
To an Exponential ramp
Posted Image
Then back again
Posted Image
You can do this by putting the ramp wave through a highpass filter, then using an LFO to modulate the cutoff. Be careful not to filter too much and make sure resonance is off.
Posted Image
Here is what miniwave #11 Bank #1 looks like when you highpass modulate the ramp wave.
Posted Image
It sounds kind of like PWM, sometimes like phasing or spectral shifting. Of course you can use any waveform in the miniwave, and instead of LFO modulation, you can use envelopes or just tweak highpass filter manually to dial in an alternative version of the waveform.
Posted Image
If you could modulate the ramp wave from logarithmic to exponential like this…
Posted Image
It would sound incredible, but I can't figure out a way to do this to a ramp wave.
Vo1t Mini Wave Table Tilting.pdf
 Filename:  Vo1t Mini Wave Table Tilting.pdf
 Filesize:  657.28 KB
 Downloaded:  426 Time(s)
Vo1t
Audio files: 373
PostPosted: Fri Feb 25, 2011 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm a bit drunk, and I don't know what you're talking about, but those pictures are awesome!
bobborries@mac.com
PostPosted: Sat Feb 26, 2011 5:47 pm    Post subject: Table Tilting Reply with quote  Mark this post and the followings unread
Perhaps I was too vague in my explanation, Sorry for that. This might clear it up.
Posted Image
sneakthief
PostPosted: Sun Feb 27, 2011 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Please post mp3's! Smile
Reminds me of when I built a pulse+triangle to saw converter: when you apply pwm the saw also changes shape ...but not nearly as nice and flexible as what you're doing.
Sneak-Thief - raw electrofunk
Vo1t
PostPosted: Sun Feb 27, 2011 3:16 am    Post subject: Table Tilting Sound Samples Reply with quote  Mark this post and the followings unread
Mini Wave Table Tilting Sound Samples
MiniWavePWM.wav
Same waveform with table tilting
 Filesize:  380.12 KB
 Duration: 0:04
 Viewed:  828 Time(s)
MiniWaveStatic.wav
Bank #1 Waveform # 11 Static without modulation.
 Filesize:  380.12 KB
 Duration: 0:04
 Viewed:  828 Time(s)
Vo1t
Audio files: 373
PostPosted: Sun Feb 27, 2011 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes I see now (sobered up). Clever! You can do stuff like this on the Nord Modular G2 too, cool to have it in a real life module!
BTW, are bobborries@mac.com and Vo1t the same person?
sneakthief
PostPosted: Sun Feb 27, 2011 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
nice Smile
