ian-s
Joined: Apr 01, 2004 Posts: 2669 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 626
Posted: Tue Jan 11, 2005 2:00 pm Post subject:
DORn |
Here are another couple of experiments to share. The first is based on the drifting oscillator discussion here on the list. Slot A contains a fairly standard dual oscillator synthesiser. Kassen pointed out the importance of non correlated noise, this approach uses a single noise source and a S&H for each oscillator. The S&H is triggered by the oscillators own output. So long as the modulation amounts vary, correlation is avoided because each oscillator takes new random values from different points in time. This I think is analogous to a real VCO which has micro shifts in its reset point due to noise and inaccuracy in the comparator/reset circuit. The effect is best heard with the two oscillators tuned to exactly the same pitch, with the modulation applied, they phase nicely, just like analogue. Probably should point out that simply detuned oscillators sound pretty good to me as well.
The second experiment, also in slot A, is with the RndClk module. It seems that if you put more than one in a patch without connecting the seed or reset inputs, they auto random seed so that the patterns are different. In this instance, I have a pair which have the seed and reset inputs connected so that they will produce an identical sequence of values. They are then triggered by separate RndTrgs that are not synchronised so that as the triggers randomly increase and decrease, the notes move back and forward in relation to each other. The effect is exaggerated by an lfo/inverter which tilts the randomness by modulating the RndTrg probability inputs.
Beautiful day today, not so dark anymore. Sorry in advance for high sugar content.
Description: |
Download |
Filename: |
Dorn-IS.prf2 |
Filesize: |
8.76 KB |
Downloaded: |
1835 Time(s) |
Joined: Jan 31, 2003 Posts: 18197 Location: Durham, NC
Audio files: 212
Posted: Tue Jan 11, 2005 3:08 pm Post subject:
This could easilly win this week's best patch of all time award.
This is almost ideal; a beautiful noodle that you can play along with in the keyboard. Magnificant sounds... Beautiful...
I'll be playing with EGW and Nikulydin in Boston this Thursday at the Lizzard Lounge. I'm going to play this at some point.
Splendid... _________________ --Howard
my music and other stuff |
cebec
G2 patch files: 31
Posted: Tue Jan 11, 2005 3:50 pm Post subject:
Yeah! This patch sounds so moving and seems so malleable and liquid that I don't really mind the sugar high!
Really nice one!
ian-s
Audio files: 42
G2 patch files: 626
Posted: Tue Jan 11, 2005 5:18 pm Post subject:
mosc wrote: | I'll be playing with EGW and Nikulydin in Boston this Thursday at the Lizzard Lounge. I'm going to play this at some point. |
I'm honoured |
mother misty
Joined: May 13, 2004 Posts: 681 Location: Ghent / Belgium
G2 patch files: 130
Posted: Thu Jan 13, 2005 1:28 am Post subject:
Sounds wonderfull! |
Audio files: 212
