CGS41 Diatonic Converter
Page 1 of 1 [6 Posts]
cleaninglady
PostPosted: Tue Jan 24, 2012 11:58 pm    Post subject: CGS41 Diatonic Converter
Subject description: Alternate trimpots question.
I have been building the MARSH Panel and was wondering if anyone knows what orientation i would have to put Bourns 25 turn Cermet Trimpots if i decided to use them instead of normal trimpots for 5K and 25K ?
magman
PostPosted: Wed Jan 25, 2012 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I used this type of pot on a recent build of this module:
http://www.rapidonline.com/Electronic-Components/50k-3296y-10-3-8-Cermet-Trimmer-Pot-68-0426
The spacing of the Y-Type trimmer is an easy fit to the holes in the PCB and it will only fit one way round.
Hope this helps.
Regards
Magman
cleaninglady
PostPosted: Wed Jan 25, 2012 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Magman
That's what i have. Bourns.
The legs are in a straight line so it can go in two ways.
That's the problem i have...
Can you remember , adjustment screw up or down ?
(If we look at the pcb with the components facing us and the 5K trimpot on the lower right...).
cheers
cL
cleaninglady
PostPosted: Wed Jan 25, 2012 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually , after looking at the page in the link you posted a bit closer ; i can see that the 'Y' leg configuration is the same as what the straight leg configuration would be with the middle leg bend forward...?
Would you agree with that Mag ?
magman
PostPosted: Thu Jan 26, 2012 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
To be honest, it doesn't matter which way round you install the trimmer, as the central wire is the wiper and this is the key connection.
Both trimmers in this application are set up as variable resistors, so you can just adjust the pot to give the required resistance regardless of which way round it is installed.
Hope this helps
Regards
Magman
cleaninglady
PostPosted: Sat Feb 04, 2012 2:32 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Mag
