CMOS Wave Shaper
Page 6 of 6 [127 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6
piedwagtail
PostPosted: Sat Sep 30, 2017 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
CMOS Cookbook 2nd Ed. goes into digital sine generation p379-385.
Apparently the heavy paper was IEEE June 1969.
There's a table p383 going mathematically into the comparative volumes of the higher harmonics.
Most of the text is ring counter generation rather than counter+xor.
The counter+xor is also the generator in the Walton Graphic Oscillator.
Perhaps the idea from Don is:
Another interesting possibility with 8- or 16-state sine-wave generators is to use two resistor summing networks to produce quadrature sine and cosine channels.
R
vladosh
Audio files: 55
PostPosted: Tue Aug 18, 2020 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
i just drew a pcb layout for 4 square to shine shapers ,those with 4015 from earlier ,wasn't sure about the supply i just added a regulator to the board ,the idea for this is to use them with the cross product module from electronotes and mix 4 shaper sinewave outputs instead of the squares from 7408 ,it's little rough but i just avoid making it double sided
 Filesize:  717.03 KB
 Viewed:  379 Time(s)
