help me understand the joystick controller
Page 1 of 1 [2 Posts]
okelk
PostPosted: Sun Jun 15, 2014 7:38 am    Post subject: help me understand the joystick controller Reply with quote  Mark this post and the followings unread
Please Help me understand the cgs joystick schematic I built.
Posted Image
I understand why the first opamp is an inverted design. easier signal mixing and winder gain range.
but, I don't understand what the second opamp is good for.
There is not really a need for inverting the signal again, because you could just install the joystick,or the pots the other way round with the same effect....or did I miss something?
Also if it is just an inverting buffer, what are the 2 47k resistors good for. wouldn't it have the same effect if you would just leave them out?
or could I tap a second, inverted cv from inbetween the opamps?
the 1k resistor in the end has something to do with the output impedance, right?
I'm just starting to learn a bit ore about electronics, understanding those simple circuits really helps me get to the point where I can design my own ones...
fluxmonkey
PostPosted: Sun Jun 15, 2014 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
you're probably right--in this case, you could just wire the joystick pots in reverse and not have to re-invert the wheel as it were. this uses a stock DC Mixer board, tho, which has the 2 inverting back-to-back. if you were wiring on perfboard, your approach should work
b
www.fluxmonkey.com
