joshs
Posted: Fri Feb 06, 2015 9:43 am Post subject:
Line Level -> Gate & Amplified Signal |
I've been searching around the Internet but haven't had much luck finding a circuit that does something like the following:
1. Takes as input a low signal... I was thinking guitar, but maybe it makes more sense to work at line level and do a little preamplification? Ideally the circuit could deal with either using some kind of trimmer. I'd want to be able to use different sources (thinking also a cheap casio keyboard, maybe even a microphone)
2. Outputs a 5v gate signal and an amplified version of the original signal (amplified enough to work in a synth circuit so it could be run through low pass filters, vca, etc)
I found some articles that mentioned the problems associate with this sort of thing (signal cutting out too soon, false triggers etc). I don't mind if it's a little glitchy though, especially if there are ways to adjust the sensitivity of the gate generator circuit.
Anyway, are there any circuits out there that could at least show the basics? I'm no electronics genius, but I've built a few things, so I have some ability to modify a circuit if it's in the ballpark.
Oh, and I have access to a +/-15V supply, so I could make use of that. |
Joined: Mar 28, 2006 Posts: 1497 Location: Kansas City, Mo USA
Posted: Fri Feb 06, 2015 10:32 am Post subject:
Suggest that you look for an Envelope Follower -- in particular, one that has a comparator to fire a trigger for you. The other function -- to amplify an instrument-level signal -- would simply be a pre-amp. _________________ -- Kevin
http://kevinkissinger.com |
wackelpeter
Audio files: 10
Posted: Fri Feb 06, 2015 3:52 pm Post subject:
Maybe something like the Korg Ms20 external Signal processor?
You can adjust Level on incoming Signal... you can set the Treshold when it Triggers ... Of course you would need as i suppose 5V Triggers and not s-Triggers like this produces...
Also wonder if my slope detector from Ken Stone could be of useful help...
will give it if i don't Forget it tomorrow a try and feed some Audio Signal in... _________________ https://soundcloud.com/bastian-j |
joshs
Posted: Fri Feb 06, 2015 11:54 pm Post subject:
I should add that I'd like to build this myself (couldn't find schematics for the MS-20 external processor)...
I gave some thoughts to how this might work, but couldn't get very far. My initial thought was to use a transistor biased so that the signal would saturate it at a fairly low level of input. But that seems like it would be problematic, because there would be an area between saturation and cut off where it would be in a linear state, which I think I'd want to avoid. Then again, maybe the linear region wouldn't be a big deal so long as noise was below the cutoff. Not really sure how to calculate the proper setup. Then I guess I'd want to use an op amp before it to buffer the input so that I could split the signal between the gate and the signal output. I really don't have the technical knowledge to design it, so it'd be great to find a solution out there to start with. Seems like something someone would have done already. |
wackelpeter
Audio files: 10
joshs
Posted: Sat Feb 07, 2015 7:10 am Post subject:
| Cool, lots of interesting stuff in that circuit, thanks for posting it! Looks like it outputs trigger and not gate? But then again it has an envelope out, which would probably be good enough if not better than what I was thinking. Any idea if that C1685 transistor is something that could be substituted with a more available transistor? And is that part of the circuit only to run the LED anyway? |
wackelpeter
Audio files: 10
Posted: Sat Feb 07, 2015 7:46 am Post subject:
that Transistor drives only the LED...
the Trigger Output is from what i think an S-Trigger... As the MS-Series work with S-Triggers (a short contact to GND)
But i think it can be easily converted to a normal Trigger or Gate... maybe the Output pin7 on the lower OP AMP already offer This... should be from what i guess be configured as a comparator with variable treshold...
guess some of our more experienced friends with more technical knowledge and Background can answer this more precise...
but i'm not exatctly sure... i only know that i converted normal Trigger and gate signals to S-Trigger with a simple circuit consisting of a Transistor and 1 or 2 resistors... _________________ https://soundcloud.com/bastian-j |
joshs
Posted: Mon Feb 09, 2015 8:11 am Post subject:
| Okay, well it at least sounds like this is worth looking into. I still have lots of planning to do (for the other circuits involved as well) so it'll be awhile before I figure this out, but please chime in if you have more advice or circuits to look into. Thanks! |
tubeampguy
Joined: Oct 29, 2009 Posts: 12 Location: Long Beach, Ca
