WavePlayer and pulsedelay
Page 1 of 1 [8 Posts]
Wobble
PostPosted: Fri Feb 17, 2017 8:02 pm    Post subject: WavePlayer and pulsedelay
Subject description: triggering and playing
I tried to think of a smart and simple way to just being able to provide a trigger signal, and it plays wave only once:
Posted Image
However as can be seen the Pulsedelay outputs a negative value even though its range is set to be positive only. Am I misunderstanding how range work, or is it a bug?
Wobble
PostPosted: Fri Feb 17, 2017 8:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also for pulse delay when in stretch mode, I am unclear about if it stretch from the end of the incoming pulse, or from the start?
Wobble
PostPosted: Fri Feb 17, 2017 8:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
About pulsedelay again, if I manually enter "1.839 s" as duration, it seems to last about 10-15 seconds. Maybe I am doing something wrong don't know.
And sorry about all these recent posts about bugs and stuff on your forum, its just that your program is very cool, so I use it alot. Smile
Former site admin
Audio files: 353
PostPosted: Sat Feb 18, 2017 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
heh .. it is okay to talk about all the bugs, things can only get better from it. Besides things are what they are, and it is not like my life depends on people using or liking Wren :-)
So, thank you for trying things. And keep 'm coming the bug reports - you will find more. What I can easily fix I will, what I can not fix easily will still be stored in my head and who knows, maybe some day I see the light :-)
Re. manually entering values ... that just does not work properly, only under some conditions it will ... sorry about that. It needs a major redo of the internal units system to make it work properly .. or so it seemed to me the last time I looked at it.
Re. things stopping to work, I'd be very happy when you could come up with a recipe to make things fail with certainty ... or even likely. Knowing how to make a bug appear is half the work of solving it.
Wobble
PostPosted: Tue Feb 21, 2017 1:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Alright, did some more testing then:
Pulsedelay outputtype "positive" also give negative values:
Reproducable every time.
How pulsedelay stretch work:
I did a test with real slow input, and it seems like it stretches from start of trigger pulse, which is also what is most useful (to me atleast). I think it would be a good idea to add that to the F1 help though.
Former site admin
Audio files: 353
PostPosted: Tue Feb 21, 2017 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, both are correct - I fixed the ouput signal type issue for the next release (the code forgot to even look at the selected type) and changed the help text a bit to hopefully make it more clear.
The stretch mode actually makes a fixed pulse length, no matter how long the input pulse width is - it will stretch a short one and truncates a long one. So this influences the positive bit of the incoming signal only.
The delay mode shifts the whole pulse in time, so its length will not change but it will come later. This will delay both the positive and negative part of the incoming signal.
Former site admin
Audio files: 353
PostPosted: Tue Feb 21, 2017 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
And sorry - could have seen the issue earlier - did not read to carefully apparently Confused
Wobble
PostPosted: Tue Feb 21, 2017 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome, thanks. Smile
