Kleebit sequencer
Page 1 of 1 [4 Posts]
Wobble
PostPosted: Tue Feb 21, 2017 4:11 pm    Post subject: Kleebit sequencer
Subject description: Chaining
So I kinda figured out how to use the Kleebit by myself since there is almost no info in the help on it. Its very handy.
But there is still some things I am unsure about:
What does the plugs underneath Loop and Norm do?
Is there a way to chain the Kleebit? I tried some things, but did not succeed.
Former site admin
Audio files: 353
PostPosted: Tue Feb 21, 2017 6:08 pm    Post subject: Re: Kleebit sequencer
They toggle the button setting, but there is no feedback on that on the button itself, just the lights indicating the 'other action'.
Hmm .. I forgot ... drive them from the same step signal, outbit goes to inbit of the next one, and connect the A, 1 .. 3 busses to the next one .. something like that .. but has been a while since I used it ... maybe there needs to be an inbit outbit loop to make it loop over a chain .. but should be possible to chain arbitrary numbers ... damn .. would need to re figure it out myself ... also need to experiment with loop mode .. needs to be off I think for a chain ...
looking at code .. yup .. when loop is on it takes its own last bit value (internal carry bit) and when loop mode is off it takes the inbit. Invert mode flips the internal carry bit only so for chaining that should be off .. and yes .. it needs a loop over inbit outbit inbit outbit .. ah .. wait .. internal carry goes to outbit, so that gets flipped in invert mode, so in a chain to have invert mode (which effectively doubles the pattern length) you need an odd number of inverts to be on ... probably one, but why not three :-)
A bit confusing still I guess .. is that any help?
Wobble
PostPosted: Tue Feb 21, 2017 6:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think so.
I just tried chaining 2. Full loop of in/out-bits, and with mode to 'once'.
That worked, thanks. Smile
Former site admin
Audio files: 353
PostPosted: Tue Feb 21, 2017 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
pwew .. and now I get some sleep :-)
The fixed divider works.
