today> Tom Bruce and Rob Snyder High Anxiety Cabaret
Frequencies
Page 7 of 9 [225 Posts]
Audio files: 400
PostPosted: Sun Sep 30, 2018 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
More upbeat and almost coherent after some usual experimental frequencies at the start.
MLfreq047.mp3
Muied Lumens - Frequencies #47
 Filename:  MLfreq047.mp3
 Filesize:  54.97 MB
 Downloaded:  556 Time(s)
Muied Lumens Base Star
Audio files: 141
PostPosted: Mon Oct 01, 2018 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice frequencies Rob Smile
epicyclus@skrogmusic.plus.com
Audio files: 400
PostPosted: Mon Oct 01, 2018 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Dave, much appreciated. Smile
Audio files: 400
PostPosted: Sun Oct 07, 2018 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some unintended clicks and pops in this, but they turned out to be intended since they have effects on them...
MLfreq048.mp3
Muied Lumens - Frequencies #48
 Filename:  MLfreq048.mp3
 Filesize:  54.04 MB
 Downloaded:  554 Time(s)
Audio files: 141
PostPosted: Mon Oct 08, 2018 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice frequ show Rob , i liked the clang / bell sounds near the start , good one
Audio files: 400
PostPosted: Wed Oct 10, 2018 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Those are from Aalto VST --- 2 oscillators with FM, but key tracked individually (and I think one was linearly instead of pitch tracked).
Audio files: 400
PostPosted: Sun Oct 14, 2018 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
A very experimental set this time... Binaural mikes into Mini KP2, with ample feedback and such noises.
MLfreq049.mp3
Muied Lumens - Frequencies #49
 Filename:  MLfreq049.mp3
 Filesize:  55.52 MB
 Downloaded:  532 Time(s)
Audio files: 400
PostPosted: Sun Oct 21, 2018 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Last frequency for a while... Smile
MLfreq050.mp3
Muied Lumens - Frequencies #50
 Filename:  MLfreq050.mp3
 Filesize:  49.18 MB
 Downloaded:  525 Time(s)
Audio files: 249
G2 patch files: 319
PostPosted: Sun Oct 21, 2018 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rob for a wonderful year of Frequencies, it has always been a pleasure to listen to them.
Hope to see you back at some time.
/me applauds
Audio files: 400
PostPosted: Mon Oct 22, 2018 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Jan. Smile
I'm sure I'll be back again. I enjoy doing these shows very much.
Audio files: 400
PostPosted: Tue Dec 25, 2018 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I loaded up a few of the early ones, first 20 or so - - - took out bits and mixed some of them together.
frequencies mix 1.mp3
Muied Lumens - Frequencies Mix #1
 Filename:  frequencies mix 1.mp3
 Filesize:  44.14 MB
 Downloaded:  449 Time(s)
Audio files: 249
G2 patch files: 319
PostPosted: Fri Dec 28, 2018 6:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
/me applauds
That's a nice mix you've made :-)
Audio files: 400
PostPosted: Sat Dec 29, 2018 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
It was infact taken from the first 29 frequencies. I'm working on the next one now, and there may be yet another from the leftovers...
Audio files: 400
PostPosted: Sat Dec 29, 2018 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Part 2 - a bit more experimental perhaps.
frequencies mix 2.mp3
Muied Lumens - Frequencies Mix #2
 Filename:  frequencies mix 2.mp3
 Filesize:  48.61 MB
 Downloaded:  442 Time(s)
Audio files: 249
G2 patch files: 319
PostPosted: Tue Jan 01, 2019 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice too!
Audio files: 400
PostPosted: Sat Jan 05, 2019 8:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan. Smile
Last mix...
frequencies mix 3.mp3
Muied Lumens - Frequencies Mix #3
 Filename:  frequencies mix 3.mp3
 Filesize:  54.76 MB
 Downloaded:  441 Time(s)
Audio files: 644
PostPosted: Sun Jan 06, 2019 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, you better stop doing these before they get too awesome, DJ PHOBoS is already getting insecure Wink
Hail the Master
Audio files: 400
PostPosted: Mon Jan 07, 2019 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you kindly Pho. You were an inspiration for these them mixes. Wink
Audio files: 249
G2 patch files: 319
PostPosted: Wed Jan 16, 2019 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Third one was nice to listen to as well.
Audio files: 400
PostPosted: Wed Jan 16, 2019 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you. In fact, these mixes have given me an idea - to record improvisations with the intention of taking the best of them and mxing them together.
Audio files: 400
PostPosted: Thu Jan 02, 2020 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm starting these up again, running on Mondays at 2100 GMT this time around, but that isn't super set in stone or anything, I might change it as I go along.
Audio files: 249
G2 patch files: 319
PostPosted: Thu Jan 02, 2020 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
re-
Cool
Shocked
cheers salut bounce too much coffee singing party! even Exclamation
for the re-f-re-quencies Cool
Audio files: 400
PostPosted: Thu Jan 02, 2020 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rethanks Jan. Very Happy
shanemorris
Audio files: 91
PostPosted: Thu Jan 02, 2020 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
YAY!!!!!!!!!!!
party time! party time! party time!
ElectroCasa
Audio files: 400
PostPosted: Sat Jan 04, 2020 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Shane. Smile
