  Twyndyllyngs Live Chez Mosc
 Forum index » Instruments and Equipment » Soft synths
Arturia Moog Modular V
Page 2 of 2 [31 Posts]
Goto page: Previous 1, 2
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Aug 21, 2003 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Indigo is a much newer and more expensive machine but I do not think it has inputs for both carrier and modulator (the synth source is the internal sound generator)
PostPosted: Thu Aug 21, 2003 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right.. true.. I checked all its openings.. close scrutiny.. This is the problem with all those modern budget synths that gets a vocoder thrown in. -Like the Novastation something.. the intent is to use the synth itself as the carrier and the only input is a mike.. which of course can be OK.. now and then but the great fun with vocoders is not using a mic and voice as the modulator.
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Aug 22, 2003 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
watch out! you could be misinterpreted and censored Twisted Evil
Reason 2.5 has inputs for both carrier and modulator, that little bastard!
PostPosted: Fri Aug 22, 2003 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Mind you, I never take the rubber glove, the hose and the baby oil with me to the music shop.
OK? So Reason has two audio inputs? Hmm.. does this mean that I can set up a second mac with Reason 2.5, sync it with midi... and use it as a vocoding instrument? I can use the M-Audio 410 for this...
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Aug 22, 2003 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
You can use any pre-recorded file as both carrier and modulator or play live one of its sound generators assigning the output to one of the vocoder input.
It should not be hard to understand for a rocket scientist like you!
P.S.
I do not think you checked all its openings Evil or Very Mad Twisted Evil
PostPosted: Fri Aug 22, 2003 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh.. sure... right... Razz
