Some poly progress
Page 1 of 1 [4 Posts]
Former site admin
Audio files: 353
PostPosted: Fri Aug 07, 2020 7:51 am    Post subject: Some poly progress Reply with quote  Mark this post and the followings unread
I'm working on making Wren polyfonic. The underlying idea is quite simple, just pass around a bit more data and let the modules compute that in separate voices.
But then there were 325 or so module types to be changed for poly mode .. some quite trivial, some a lot of work. I've done most of the modules by far, but there still are 60 or so that need attention - amongst them the MIDI modules, and also some that will stay monophonic probably.
Also made a couple of new modules for poly related trickery, like voice merging, splitting, viewing, selection, stuff like that.
But anyway got over 250 done, there probably still are some bugs in those, so was making a couple of test patches and made some recordings of the current one that tests poly sequencing. Both with five voices, one with the same tempo over al lthe voices and another with tempo changes, which can also differ per voice.
The patch :
Posted Image
The CPU level is a bit high here as I ran Wren in debug mode.
And the recordings are below:
2020_08_07__tempo_constant_poly_sequence.mp3
blue hell - wren polyphony test constant tempo
 Filesize:  1.75 MB
 Duration: 1:55
 Viewed:  1664 Time(s)
2020_08_07__tempo_varied_poly_sequence.mp3
blue hell - wren polyphony test varied tempo
 Filesize:  2.64 MB
 Duration: 2:53
 Viewed:  1694 Time(s)
Adis
PostPosted: Sun Aug 09, 2020 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice!
Adis
PostPosted: Sun Aug 09, 2020 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you post this patch?
Former site admin
Audio files: 353
PostPosted: Sun Aug 09, 2020 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I could do that, but you can not use it yet - will first have to make a new release for the poly stuff, and am still optimizing things a bit and debugging - still finding some small errors here and there.
Edit: If I dont forget it .. I'll post a recent set of patches [at https://bluehell.nl/wren/patches/forums.html] when I make a new release ... hmm .. I'm not sure that that test patch still exists Rolling Eyes
