Universal Preamplifier from 5V Single Supply
Page 1 of 1 [12 Posts]
Ruebezahl
PostPosted: Wed Nov 05, 2025 12:41 pm    Post subject: Universal Preamplifier from 5V Single Supply Reply with quote  Mark this post and the followings unread
Hey everyone,
i am trying to design a Preamplifier that is kind of universal, eg it is suitable for contact mics, guitar pickups and regular microphones (not the ones that need phantom power or plug in power probably, as that would mess with the other input options, right?)
I want to runt it from USB, so 5V single supply, and to keep it relatively simple, affordable and with not too hard to find parts. Of course i hope the sound is as good as possible, considering the other limitations, but it is not meant to be super HIFI, not going to do field recordings, studio recordings or something with it.
The use case will be in a bigger circuit that is mostly for education and playing around. giving workshops, playing around with different ways to amplify. there will also be some oscillators to modulate that signals, or being modulated by those signals. i might do a seperate track about it, but this is mostly me being curious about this particularly question.
I already breadboarded something with the LM358, and can confirm it works, at least for the contact mic, and the guitar pickup, but i would be happy if anyone has some ideas how to improve it, make it more universal, or less noise (at the moment i find it okay, but who knows what kind of different environments, power supplies, pickups this will have to deal with in the future, especially it will be patchable. so if there is room for improvement, i am all for it!)
I did find the MCP602 as a possible alternative, which seems to have lower noise, higher output voltage swing and also a higher Input Impedance than the LM358. Its easily available and while a bit more expensive, its still quite affordable.
What do you think? Any other ideas? Or any improvements to my circuit?
Thank you Smile
 Filesize:  53.55 KB
 Viewed:  175 Time(s)
Audio files: 83
PostPosted: Wed Nov 05, 2025 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have used the LM358 a few times, and I always find it to be noisy.
If it's a pre-amp, then you should be able to use any amplifier circuit since it's just boosting up to line level. If it's a power amp, then you need something that can drive speakers.
You can get little diy amp kits for a decent price. I'd look into that option.
JacobWatters.com
phobos
Audio files: 728
PostPosted: Wed Nov 05, 2025 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Although it might not be very noticeable you're currently only amplifying half the waveform when using a
single supply, the other half is going to be clipped off. You could add another 1M resistor from pin3 to +5V
and add a capacitor (1uF..10uF) between R9 and GND. Ideally you'd use a scope to look at the output
waveform while adding a sine or triangle signal to the input.
A single supply, low voltage preamp can be a bit tricky without "specialized" opamps. It does depend a bit on
how large you want the output amplitude to be. A rail-to-rail high impedance opamp, which the MCP602 seems
to be, would definitely be an improvement.
There is also the option to not use an opamp at all and go for a transistor preamp. Those do tend to be low noise
but the design is a bit less straight forward.
Also keep in mind that a (piezo)contact-mic can produce some fairly high voltage spikes, however the current is
very low and if you have a 100K input impedance it probably won't do any harm to the circuit. I haven't used guitar
pickups myself but I think that, since you aren't going for hifi, a mic and guitar are pretty much interchangeable.
The Golden Shrimp Guild
Sven
PostPosted: Thu Nov 06, 2025 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
first thought here: I would choose an opamp that can run at 3V.
Good luck with your project.
Sven
Ruebezahl
PostPosted: Thu Nov 06, 2025 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your opinion and tips, i think i will go for that one then Smile
And you are right about the bias, i actually was transforming that circuit from a standard amplifier circuit for dual supply, so i was not really sure what to do with the ground-connections. So with a single supply, the input should be biased to center (2.5V), kept in the middle, but the feedback loop (or R9) is hooked up to ground (0V), yes? Because in a dual supply, it should be also going to the center, not (-V), that part is a bit confusing for me.
Originally i made a virtual ground and connected all the connections to ground in the original schematic to that one. But then i was not sure where i should connect the ground of the connection going to the amplifier, because on the amplifier board (PAM8403) the power supply ground was connected to the ground anyway, so when i connected the virtual ground to the ground of the amplifier, it was just dragging the whole virtual ground down (naturally), but it actually worked. That's why i decided to just scrap the whole virtual ground thing.
Hope i expressed my thoughts in an understandable way, if not, nevermind, it it works it works Very Happy
Ruebezahl
PostPosted: Thu Nov 06, 2025 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Sven wrote:
Sven
Thank you, do you mean i should run that opamp at 3V, like regulate it down. Or just to choose one that COULD also run at 3V? The MCP602 could do that.
Sven
PostPosted: Thu Nov 06, 2025 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I mean using an opamp like the MCP602 which can operate down to a 3V single supply because you get 1V more "headroom" than with the LM358. The 602 has also 4 times the gainbandwith and a bit less noise.
Ruebezahl
PostPosted: Thu Nov 06, 2025 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, when you say amp kits you mean power amps? No for driving speaker i will use PAM8403, its only about thee preamplifier. for that i didn see many kits, but also i am not really looking for a kit, (unless as inspiration), i am designing a board (which the preamp will just be one part) and want to make many of them, so it should be kind of included in the design.
It's just many preamplifier examples i find are either specifically for contact mic, microphones or guitars, or run from dual supply. so i wanted to find a universal solution (kind of like what you have on a mixer or an audio interface) that runs on a low power single supply.
Ruebezahl
PostPosted: Thu Nov 06, 2025 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Sven wrote:
Got it! Yeah i think i will go with the 602, and also implement the changes phobos suggested. thanks for your thoughts.
I will share the complete project once its a bit closer to finish, right now its a bit messy.
Audio files: 83
PostPosted: Thu Nov 06, 2025 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I meant a preamp kit, but that's cool if you want to design your own.
You mentioned adding more to this circuit - I highly recommend that you change the power supply. If you are mixing a few sounds together, then you are going to want more headroom too (at least +/-12V). As you add more stuff and your circuit becomes more complex, you are going to run into issues trying to do it all on a single 5V supply.
JacobWatters.com
Ruebezahl
PostPosted: Thu Nov 06, 2025 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the suggestions, but i am not trying to build a modular synth, it's a small circuit board meant for use in workshops with kids and grown ups to have some fun with basic electronics and sound experiments. I figured USB is the most accessible way to power it.
I won't add too much more, just two oscillators with cmos chip and a modulator with a vactrol (and a buffer for that.) The biggest current draw will be the on board amp and speaker. It will be pretty Lo-Fi but i already breadboarded it and it works kind of fine (even with the LM358 it did).
But again, i appreciate the suggestions, and i understand i should post some more info about the circuit, in order to explain myself better, just have to clean up the schematic a bit. Very Happy
phobos
Audio files: 728
PostPosted: Thu Nov 06, 2025 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
yes
no, normally that would indeed go to GND or for this case 2.5V as well, but you can circumvent this with a capacitor in series with R9.
To be honest it's a monkey see monkey do thing for me,. I don't know the exact details of how it works just that I have used several non-inverting single supply
opamp designs in the past that used this setup and they worked perfect. Something with biasing the DC voltage (probably because both inputs of the opamp will
be kept at the same voltage by the opamp itself) but not the AC voltage. I could look it up and try to regurgitate what I find but that seems a bit silly. If you are
interested in how/why exactly it works you can probably find some detailed explanations that will be far better than I'd be able to give you.
