Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Thu Dec 08, 2005 4:54 pm Post subject:
Waldorf Microwave II/XT/PC control Subject description: The ultimate G2 MWXT editor |
For any users out there with both a g2 and a microwave II/XT/PC, here is an alternative for the soundtower / sounddiver editors. All standard functions can be controlled (well, except for a few functions I'll never use), but no support for changing user-wavetables or -waves.
To be used in conjunction with a midi tool like MidiOx. The performance exists of 4 patches; slot A and B feature normal CC sending knobs, which have been assigned to the corresponding midi-in CC's as well (for easy use with external knob-boxes; I'm an engine user with a bcr2000). Few exceptions, these are noted in text-modules.
Slot C and D transmit CC's on midi channels 15 and 16, and these should be translated using MidiOx or similar tool to SysEx. I've included a zip of the mapping file for use with MidiOx, as well as the MidiOx profile file that I use for my specific setup.
Hope this is useful for some of you, it took me a few nights to set up but it seems to work like a charm now
Edit: In the FX areas are some text modules that explain long lists of values; for example filter1 settings, modulation sources and destinations, etc. Additionally, "synth settings" options like midi channel per slot, send/receive controllers etc are very important to set properly for your specific setup, of course.
| The ultimate G2 MWII/XT/PC editor ;) |
 Download (listen) |
| Filename: |
MicrowavePC_v5 ModMatrix incl.prf2 |
26.76 KB |
| Downloaded: |
2248 Time(s) |
| MidiOx profile (specific for my personal setup, but might be enlightening for other users; .ini file) and mapping file (.oxm file) zipped together |
 Download (listen) |
| Filename: |
MidiOxfiles.zip |
1.84 KB |
| Downloaded: |
1141 Time(s) |
cappy2112
Joined: Dec 24, 2004 Posts: 2523 Location: San Jose, California
Posted: Mon Apr 13, 2009 1:17 pm Post subject:
Re: Waldorf Microwave II/XT/PC control Subject description: The ultimate G2 MWXT editor |
| Fozzie wrote: | For any users out there with both a g2 and a microwave II/XT/PC, here is an alternative for the soundtower / sounddiver editors. All standard functions can be controlled (well, except for a few functions I'll never use), but no support for changing user-wavetables or -waves.
Edit: In the FX areas are some text modules that explain long lists of values; for example filter1 settings, modulation sources and destinations, etc. Additionally, "synth settings" options like midi channel per slot, send/receive controllers etc are very important to set properly for your specific setup, of course. |
Hey Fozzie- I've got to try this on my Microwave 2.
Looks like a fun idea.
I love Midiox- best free software in the world, but why do you need to convert to/from sysex? Are not all the XT's parameters controllable via CC's?
You gotta love Waldorf's midi implementation and documentation. Complete and thorough! _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
