today> Tom Bruce and Rob Snyder High Anxiety Cabaret
DlyShiftReg bug?
Page 1 of 1 [9 Posts]
Rix
G2 patch files: 25
PostPosted: Sun Aug 22, 2004 3:39 am    Post subject: DlyShiftReg bug? Reply with quote  Mark this post and the followings unread
I was struggeling with an idea for a patch: 'sequence by the numbers'.
The idea is to have constants (numbers) represent the binary pattern that then should be played. So one constant would represent the sequence for a hi-hat, another for a snare, etc.
I tried to use the DlyShiftReg for this, but it does not seem to work as expected.
When I have a number with a single bit as input (e.g., 4, 8 ) and then shift it by a clock, this is what I would expect:
100 (the input number)
010 (after the first shift)
001 (after the second shift)
instead, what happens is that the bit is 'smeared out' like this:
110 (after the first shift)
111 (after the second shift)
This does not seem right for a shift operation.
Or has anyone another idea how to 'scan' a number bit by bit and send the result (0 or 1 ) to a module?
Richard
Rob
G2 patch files: 109
PostPosted: Sun Aug 22, 2004 4:16 am    Post subject: Re: DlyShiftReg bug? Reply with quote  Mark this post and the followings unread
Richard
Send in a little patch, exampling the behaviour you found. Then its better to check out what goes wrong.
Rix
G2 patch files: 25
PostPosted: Sun Aug 22, 2004 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a simple patch.
Ths single bit (made visible in ADConv1) is smeared out by the DlyShiftReg1 (made visible in ADConv2)....
Richard.
[moderator : For some reason the attached patch (seqwie.pch2, Patch to make a sequencer by reading the bits of a constant value.) generated a file not found message, I removed the invalid link to it - Blue Hell]
Rob
G2 patch files: 109
PostPosted: Sun Aug 22, 2004 5:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Richard.
Seems to me that you're clocking in the same information again and again. Note that the input to the shift register should have the information only on the first clock it gets, on sbusequenct clocks the input should be zero. It's a serial vs. parallel kind of issue.
What you could try to do is connect a two input switch with its output going to the input of the shift delay and 'gate' with one pulse of the ringcounter, so only one bit can get shifted in during eight clock pulses of the clock. By suppressing the bit that controls the switch the shift delay should recirculate.
But perhaps you need eight of these shift registers to shift the eight bits from your constant value...
seqwie2.pch2
 Filename:  seqwie2.pch2
 Filesize:  1.01 KB
 Downloaded:  1327 Time(s)
Rix
G2 patch files: 25
PostPosted: Sun Aug 22, 2004 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm...
I modified it slightly, so that the whole number is on the 'On' switch input.
The number also starts with a 101 pattern now.
But I still so not see the 101 pattern shifted to the right, although it is presented only on the first clock pulse...
Oh well, it seemed a nice idea to use numbers for pattern generation.
Richard
seqwie3[1].pch2
 Filename:  seqwie3[1].pch2
 Filesize:  1 KB
 Downloaded:  1145 Time(s)
Rob
G2 patch files: 109
PostPosted: Sun Aug 22, 2004 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Richard
Hé, never say never... Smile
seqwie4.pch2
 Filename:  seqwie4.pch2
 Filesize:  1.27 KB
 Downloaded:  1304 Time(s)
Rix
G2 patch files: 25
PostPosted: Sun Aug 22, 2004 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hé, you have done it!
Thanks vey much. Now I can use the D7 output of the ADConv2 to trigger the sounds. And of course add some more constants...
Gracias.
Richard
jamos
G2 patch files: 39
PostPosted: Sun Aug 22, 2004 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I've done some experiments with the G2 that lead me to believe that Clavia does not use standard binary for at least some of its numeric storage. I think that the low bit represents either 1/2 - if the control's range is numipolar - or the minus sign for a bipolar value.
This is evident by looking at the output of the A/D convertor.
Rob
G2 patch files: 109
PostPosted: Tue Aug 24, 2004 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, the 128 bit is actually the sign bit and the 1 bit is actually 1/2 units. To convert the 64 values between 0 and up to and including +63 it suffices to use the middle six bit outputs, or inputs to the DA.
Numbers is all a matter of interpretation and the 'value' that people assign to numbers. Like the number 12 can mean little to you, but a whole lot to me. Smile
