Chrono
Audio files: 37
G2 patch files: 38
iPassenger
Joined: Jan 27, 2007 Posts: 1067 Location: Sheffield, UK
G2 patch files: 78
Chrono
Audio files: 37
G2 patch files: 38
Posted: Mon Aug 18, 2008 1:32 pm Post subject:
tnx
Quote: | but it didn't work properly when you hold one key and then play another and then release that second key.. the pitch should slide back down/up to the first note.. instead yr patch was holding that second note. |
You can set the mono module to "Last" i think thats what your aiming for. i used it on "Hi" for special trigerring with the Lopass filter |
Chrono
Audio files: 37
G2 patch files: 38
Posted: Tue Aug 19, 2008 5:40 am Post subject:
Does anyone know how to make a polyfonic Unison patch with the "Poly Keyboard and Voice no." output? |
Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Chrono
Audio files: 37
G2 patch files: 38
Posted: Tue Aug 19, 2008 6:36 am Post subject:
i've listened to both, and these both are not real unison like a access virus, nord, ms20, microkorg etc handles unison. I really believe my patch does handles unison as it should. So the more voices you set in a particular slot on your nord the more (in this case)saw's your slot sends through the VA section. the OSC KBD tracking is off and the pitch is controlled with the mono keyboard note module. The detune is the voice no out to the osc pitch input.
But then i once read somewhere that it theoreticly wasnt possible to do polyfonic unison on old analog hardware. So in this case becouse the g2 represents a modular system to make analog emu's that this might also be the case with the g2?
i love the g2ian's patch though but isnt that more like "Chrous" "Ensemble" ?
i think unison should use a lot of voices. thats where it's for and especially for my hardcore leads its a must. the 22 voice unison sawlead(Screach) sounds are great with my unison synth patch and are better than my Access Virus A wich only has 12 max voices. The only thing is that my virus A allows me to play 2 polyfonic notes with 6 unison voices.
I hope we can figure that out on the g2.
Quote: | when you hold one key and then play another and then release that second key.. the pitch should slide back down/up to the first note.. instead yr patch was holding that second note. |
i did some more testing and you are right i diddnt notice that yesterday! thanks for the fix |
iPassenger
G2 patch files: 78
Posted: Tue Aug 19, 2008 6:51 am Post subject:
no worries.
I think you could achieve yr 2 note poly unison, if you used one slot to accept midi information (say slot A), set to two note poly and use the voice number to split the send of the control data between two internal busses, one to a slot (say B) for the first voice and one to a slot (say C) for the second. Then these slots (B + C) could be monophonic unison as in the original patch (e.g. set to say 6 note poly) but as you would have two independant versions they would give u 2 note poly.. Problem would be controlling both units in terms of the patch settings etc... as everything would need duplicating. + you would pretty much need to make this a performance rather than a series of patches. _________________ iP (Ross)
iPassenger
G2 patch files: 78
Posted: Tue Aug 19, 2008 7:04 am Post subject:
Actually you can probably do it with two Slots.
If you send the voice 1/2 information from Slot A through the busses too it may well be possible to keep the unison synth (say in Slot B) in one slot but still have two voice poly. Though i am just thinking this out at work so no real idea if i am right here. _________________ iP (Ross)
Chrono
Audio files: 37
G2 patch files: 38
Posted: Tue Aug 19, 2008 7:49 am Post subject:
Sounds interessesting, i'm not really sure how you would patch that but that might seem like a usefull idea! |
Chrono
Audio files: 37
G2 patch files: 38
Chrono
Audio files: 37
G2 patch files: 38
iPassenger
G2 patch files: 78
ian-s
Joined: Apr 01, 2004 Posts: 2670 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 626
iPassenger
G2 patch files: 78
Chrono
Audio files: 37
G2 patch files: 38
Audio files: 278
Posted: Tue Aug 26, 2008 4:22 pm Post subject:
Sneiterheadz wrote: | somehow the attachment did not upload... |
You ran out of disc quota, please try again, I gave you some headroom. _________________ Jan
Chrono
Audio files: 37
G2 patch files: 38
Posted: Tue Aug 26, 2008 4:44 pm Post subject:
thanks!! still beeing up so late?
well in the meanwhile i've edited my last post 10 times :p the 32 voice version is up and running! enjoy...
(now the virus owners can be a little jalous) |
dorremifasol
Joined: Sep 28, 2006 Posts: 814 Location: Barcelona, Spain
G2 patch files: 49
Posted: Mon Sep 01, 2008 2:19 pm Post subject:
Great patch! thanks _________________ Cheers,
Albert |
G2egory
Joined: Nov 19, 2004 Posts: 69 Location: Charlottesville VA
Posted: Mon Sep 01, 2008 3:09 pm Post subject:
Thanks for sharing your great patch! Successfully programing 32 voices into a fine sounding patch is a substantial accomplishment. Variation 2 is one if the most exciting in-your-face lead patches I have heard in a while, especially if you play it with keyboard hold activated to drive the bass past. You stick that variation in the bridge of a song and folks are going to quickly realize you ain't playing no electric piano.
Gregory |
Chrono
Audio files: 37
G2 patch files: 38
Posted: Tue Sep 02, 2008 3:02 am Post subject:
Thanks guys,
glad you like it |
