Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 74
Posted: Sun Nov 21, 2010 11:47 am Post subject:
Ds7 core "synth" (i guess)
ok after several attempts at making a ds7, i failed bigtime. sooooo, i started touching wires around and got some interesting sounds (very unprofessional i know :p ) but anyway, here it is
ds7coresynth.mp3
Filesize:
1.05 MB
Duration:
1:09
Viewed:
1757 Time(s)
Filesize:
71.58 KB
Viewed:
613 Time(s)
Filesize:
77.11 KB
Viewed:
601 Time(s)
Audio files: 74
Posted: Sun Nov 21, 2010 3:16 pm Post subject:
it was actually the triggering that was causing the problem, it never really worked. just had a weird sort of effect, the more i turned the "delay" knob the longer it took before any sound came out. checked the schematic loads of times, i must have missed something. i still have another one of these boards and it would be nice to actually get this thing working. so any ideas will be appreciated.
1) I'm having a similar problem in a similar circuit: When triggered, the envelope start is delayed instead of the expected fast Attack.
2) I can't believe I mis-represented to bubzy the level of helpfulness usually available here. _________________ Revenge is a dish best served with a fork... to the eye
Audio files: 21
Posted: Sun Nov 28, 2010 8:26 pm Post subject:
At the risk of saving face for Richard, may I suggest hanging a large value resistor (1-5.6Meg) between the input jack and ground? On all my drum modules with a cap in to the circuit, I have to do this to get it to trigger properly. _________________ Synth DIY since 1977!
Now I need to figure out why there's no Decay, despite increasing the cap or the Decay pot. _________________ Revenge is a dish best served with a fork... to the eye
